54 minutes ago, UNR33L said:
Good ol' Vegas, got some bad stories from there but you know what they say
"its not gay if the balls dont touch"?
speaking of wastes of money, driving the pulsar was short lived. Thankfully everything mechanical seems to be working. before it was at a workshop, now its on the same property as where i live. so at least thats something.
I would get pulled over, defected for not enough handbrake clicks, then the car would be stolen in the 15mins I leave it parked outside my house.
Then it would get recovered and the gearbox is stuffed so the car gets written off, then after I've bought the car back, find out the previous owner did a turbo and manual conversion on the car. Then I would have to wear a flat brim hat constantly, ask 100 stupid questions on SAU and make up my own sticker design for the Facebook page I manage. And then I wouldn't be allowed to enter a Vic drift event until I've knocked up a chick from Moe and have to fit a pram in the skyline alongside the bolt-in cage and 4 sets of tyres.
Skylines: not even once.
  • Like 1
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
