Vic Wasteland Thread - 15.0
R31Nismoid
 Share
so after switching to Telstra a few months ago, I get a letter in the mail last week saying NBN is now available in my area... before I made the switch the NBN website indicated it was not in its soon-planned areas. Doesnt really matter because Internode isnt listed on the providers list anyway. Am happy with the cable currently so will stick with it.
Yeah I got a NBN letter too from internode.. yet I go and check the NBN site and same thing, no progress or any info - pretty pointless site I guess, kinda. Pat fix it :)
Currently fixing my bill with Telstra online chat after changing plans.. ofcourse my next bill was all f**ked up but I expected that..
Must be hard to run a competent ISP
Edited by UNR33L
ipvanish will work a treat on NBN, hotels, airport lounges maccas Mc WiFI the works.
I'm moving to that when we finish the house.
the above was just on the phone as wanted to check some speeds.
Telstra online chat has been my go-to for dealing with (numerous) issues. I can do other shit while I wait for a response and can hear when they respond. It takes a few bots/foreigners to get through to someone who can help but soooo much easier than the phone or going to a store.
Am currently on my 3rd debit card in under 5 years. The insert chips all die within 18 months. Then you gotta do the stupid dance of insert, fail, swipe, insert, fail, swipe etc.
Anyone else here have/had issues? excessive heat maybe? I thought maybe electromagnetic fields, but the swipe strip is fine.
3 hours ago, dezz said:
Any downside to nbn like the government knowing what genre of porn I may or may not be watching? Will ipvanish etc still do its job on nbn?
Exactly what I'm afraid of in a few years, government seeing everything nek minit in court for all the piracy n shit.
When I worked at a small ISP we'd get warnings all the time from all the big movie makers and have to give the customer a warning, I've been downloading movies with Telstra for 15 years never once received a letter.. clearly they just don't give a f**k. I dunno about the government though?
 Share
    • Wait, the flappy paddles or sequential is the small penis indicator?  Either way, I can't afford it.
    • You and me both. If I ever get it running again, I'll have to look into cruise control.
    • Yeah most people that have heard it said it was fine but it's always had me slightly worried. Oil pressure I can't remember off the top of my head but it has plenty, I run 10w60 You're probably right mate, best get ordering some shims! Guessing Nissan is the best place for them?
    • Just wanna preface this and point out I'm a mechanical fitter by trade but have had very little rebuild/machining experience, but I am keen to learn, hence this project. Bit of a write up here so bear with me, just want to make sure I do this right  I've got an rb30e currently pulled down. Planning on putting a 25 head on it and running it in my s14.  Not chasing huge power so I'm just going to try get away with factory bottom end for now.  Started measuring the crank the other day, realised my budget daytona micrometer set wasn't up to the task (surprise, I know). They only measure to 0.01mm but the Nissan specs are to 0.001mm. Anyway, I started measuring anyway and came away with the mains being inline with the oem spec, as well as the big ends, except for no. 5. I consistently got a measurement of a hair over 49.96mm, where all the others were pretty spot on 49.97mm. The lower spec for grade no.1 is 49.961mm. I'm getting access to some better gear my next days off to double check everything, but in the case that the big end is right on that bottom spec, is it pretty much just a case of straight to the machine shop for machining and oversized bearings? I understand I need to measure the tunnel as well to work out my oil clearance, but it's the different grade bearings in the manual that are confusing me. What is generally the process when one journal would still technically be in spec, but in a different grade?  Thanks for coming to my Ted talk
    • You need to visit Ipswich. Plenty of clapped out R32 and R33s running around here as daily drivers. And when I say clapped out, they're how you'd look at a VN, when it's the year 2010...
