2 hours ago, emts said:
how did they build a 6L V8 with
" 145 hp (108 kW) at 3600 rpm and torque to 270 lbf·ft (370 N·m) at 2000 rpm "
its funny because america's V8's had barely changed since the 40's. and when they went to alloy heads and had to change due to oil crisis, all their new motors went to shit. pretty funny really.
FWD V8? i wouldnt say no haha but when would that ever be a good idea?
the fleetwood pictured was one of the last RWD
but really when you only have 100 kw, though a old 3 speed auto so prob 60 kw at the wheels, and around 100 kg sitting on top,  torque steer would never be a problem.
Not that they were blisteringly fast cars by any stretch, but half of it is that they didn't rev out far or need to for that matter. Those V8s still pull nicely with their torque for the first few thousand rpm. The aftermarket / drag scene in the states was as fast as ever / still breaking records as far as I know, it's just factory vehicles that went down on power in Eder to meet "stringent" new emissions laws etc. There was also the rise of small displacement engines which probably took away development from the V8s combined with low sales.
We did a similar thing here with our 308 VL vs the RB30 and the 304 vs Buick 3800 motors. The V8s were still a tad quicker everywhere in spite of similar power.
tl;dr the yanks aren't that shit at building engines
5 hours ago, joeyjoejoejuniorshabadoo said:
hey... top 10! lol
Birds you loser...
Given I don't post anything but opinions, all this says is that my opinions are popular even if it's amongst a niche lol
holden 5L V8 from same year (WB statesman)
  • Power: 126kw at 4400rpm
  • Torque: 361Nm at 2800rpm
so more than 10% more power for 16% less capacity
(the HDT Magnum having 188kw for the same 5l)
or Ford had  149 hp (111 kW) and 325 N·m (240 ft·lb)  for the 4.1 straight 6.
add to that 200kg weight advantage..
translation the yanks should have talked to the Aussies....
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
