Dem MS paint skills right der'
Back to work.. break went too quick but saving my annual leave for a March holiday me thinks..
On the bright side at least I'm working from home and most of the customers aren't back at work yet
Edited by UNR33L
3 minutes ago, Kinkstaah said:
Back to work AAGGGHHHH f**kin people like to report IT problems the second they come back holy shit.
MATE I CANT LOGIN I CANT SENT EMAILS I CANT WIPE MY ASS I CANT ACCESS A FILE I DELETED A FILE BY ACCIDENT
THE VERY FIRST SECOND I COME BACK FOR THE YEAR I MUST PRINT HOLY SHIT DONT YOU REALISE HOW MUCH I NEED TO PRINT I NEED TO BE PRINTING THINGS ALL THE TIME TO LIVE
  • Like 1
Lol, I forgot about printers - the amount of shit people print when it could easily just be viewed or sent as pdfs..
At least the older generation that do this is slowly dieing off in the workforce, yes there's a direct correlation from age to printing everything
I've got another good one, HOLY SHIT I CANT SCAN TO EMAIL IT TAKES 5 WHOLE MINUTES TO COME TO MY INBOX
Edited by UNR33L
Just realize I have ~8700 posts on SAU, I haven't even owned a skyline in 5+ years.. what am I doing with my life? I don't even venture out of Vic wasteland, and been a member for 10 years, since I was 17 and got my 4 door r33 lol
Edited by UNR33L
21 minutes ago, joeyjoejoejuniorshabadoo said:
Faaaaark the printing thing. All the old people in the office sit at desks with 3 screens but use 1 and print like 100 pages a day
Pretty much this, doesn't matter what company. Law firms are the worst, folders of papers covering the offices.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
