damn some dude was doin some mad back reading liking a post of mine from page 99 :\
I don't know what's weirder, the fact some guy with 0 posts read 99 pages of esoteric conversation, or the fact we were actually talking about cars
On 2/25/2017 at 5:00 PM, Mohsen said:
you know whos to blame for losing your job in the first place leigh?
Just that our biggest customer left us basically, we think due to cost cutting. They never really gave a 'reason'
2 hours ago, Odium said:
Were you the reason that customer left?
for fks sake leigh...
Nah the director was an ass though, the amount of staff turnover there is so high that recruitment agencies don't even want the work as they know what's gonna happen.
All good in the end though, turned it into a positive by making more coin now. Although I'll miss working from home.
Them feels at open for inspections when the real estate agents don't even look at you with a Chinese buyer in their presence...
...or neglect to tell them to take off their shoes lol
I know most people don't understand nor care what a marketing department does, but someone tell me what the f**k this has to do with us?
Further, to even dignify her stupid issue, what's the solution? Move our building further down the road?
ETA until she gets in a fender bender.
Place your bets here folks.
52 minutes ago, joeyjoejoejuniorshabadoo said:
I'd say that's the problem with IT nerds... You actually convince yourselves that you need the latest program to send an email
Or that Mac is infinitely superior to PC, or the other way around, at displaying and transmitting essentially the same content
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
