1 hour ago, Leroy Peterson said:
I'm getting spud mixed up with other things...
actual informative post about the drilling plan (but not actually related to results or value or anything): https://hotcopper.com.au/threads/ann-operations-commence-at-icewine-2.3312384/page-32?post_id=23523786#.WOMZ7LgQ_IU
4.5
$600 in profit today...damn you temptation.
12 minutes ago, UNR33L said:
Take own advice and hold off :P
$870 profit now on close
Yeah I'm holding off. This well is the make or break for 88E IMO. Still think it will sink post spud like last drill, but not worth the risk that it may not.
what date? ill sell the day after lol
4 hours ago, UNR33L said:
in typical 88e fashion, straight back down after a good day :P
You had your opportunity to short trade it...
Can actually blame London for this one. They didn't continue with our optimism. Someone bought up big in Aus and we carried on...spec shareholders are incredibly knee jerky for people who are supposed to be investing long term...
I'm wondering where V-spec performance get the money/capital to buy some of the most expensive GTRs that pop up for sale. I'm not too cluey on how supercar used car dealerships run, but when starting from the ground up it must be a massive uphill battle until properly established.
Looks like they almost have more cars for sale than they've sold since opening. I wonder if someone is fronting the cash as like an investment or buying overseas then giving it to the dealer to sell, dealer sells the car (eventually), both original buyer and dealership make money. The one getting pinged is the customer since theyre paying exorbitant prices for cars that sometimes dont have an accurate expected value.
https://www.vspecperformance.com.au/temp2
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
