1 hour ago, Leroy Peterson said:
I'm getting spud mixed up with other things...
actual informative post about the drilling plan (but not actually related to results or value or anything): https://hotcopper.com.au/threads/ann-operations-commence-at-icewine-2.3312384/page-32?post_id=23523786#.WOMZ7LgQ_IU
4.5
$600 in profit today...damn you temptation.
12 minutes ago, UNR33L said:
Take own advice and hold off :P
$870 profit now on close
Yeah I'm holding off. This well is the make or break for 88E IMO. Still think it will sink post spud like last drill, but not worth the risk that it may not.
what date? ill sell the day after lol
4 hours ago, UNR33L said:
in typical 88e fashion, straight back down after a good day :P
You had your opportunity to short trade it...
Can actually blame London for this one. They didn't continue with our optimism. Someone bought up big in Aus and we carried on...spec shareholders are incredibly knee jerky for people who are supposed to be investing long term...
I'm wondering where V-spec performance get the money/capital to buy some of the most expensive GTRs that pop up for sale. I'm not too cluey on how supercar used car dealerships run, but when starting from the ground up it must be a massive uphill battle until properly established.
Looks like they almost have more cars for sale than they've sold since opening. I wonder if someone is fronting the cash as like an investment or buying overseas then giving it to the dealer to sell, dealer sells the car (eventually), both original buyer and dealership make money. The one getting pinged is the customer since theyre paying exorbitant prices for cars that sometimes dont have an accurate expected value.
https://www.vspecperformance.com.au/temp2
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
