250HP at wheels from APR site...not KW.
Edit: yes this is a GTI but they claim the same for all the E888 motors so the R S3 blah blah whatevers
That's not a mk7 and the R and gti are not the same motor. The R has a much larger turbo.
With the correct graph, Apr state 354hp at the wheels for the mk7 r (264kw)
Is it possible to retrieve data from the SSD? backed up the SATA drive with the dock, if I can back up the SSD I'll be set..
After that, will doing a fresh install of windows solve my boot issue, or am I gonna have to take it back to centre com?
My prediction of 88E falling post spud (a nothing event) came true
But I did not predict a small spike occurring today over a nothing update from DW essentially saying "everything is going fine"
The short term reactions to long term investments never cease to amaze me. The buyer behavioir in a nutshell is "everything went as expected in the day to day operations of a company today, time for me to buy in".
14 minutes ago, Leroy Peterson said:
hey Leigh, I have one these lying around if you want it cheep for one of your many motorbikes.
https://ecliptech.com.au/shift-i/
No need brah I got one of these bad boys laying around too
https://www.mxstore.com.au/p/Trail-Tech-Suzuki-DRZ-RMZ-250-450-Silver-Vapor-Com/75-301?gclid=CjwKEAjw3KDIBRCz0KvZlJ7k4TgSJABDqOK71ezh5hqTPUGrwJC3S8UyMNZoUCoNCzm7o7_rqEGYQBoCCx3w_wcB
If shares were easy to predict everyone would be a millionaire
how do you install it?
my current shift light is not giving me much joy
If everyone were a millionaire our dollar would be so inflated that your Falcon would be worth a few mil.
Reactions are usually easy to predict, events not so. Knowing the former can give you a bit of an advantage.
Brah call MSI tech support, sounds pretty bricked if you can't get into BIOS. Probably needs a motherboard replacement done by one of their techs.
Or if you are baller enough just buy a freshie, get your MSI one fixed then sell it when you get it back.
Ric must be a real POS - how often you actually use it? :P don't you get a laptop through work anyway?
Not often lol, it's pretty clunky but does the job
I have an X1 Carbon for work
1 hour ago, dezz said:
Yeah I'll call em just wanna back everything up first if they're gonna wipe it in the process..
Any way to backup the SSD?
If it's physically removable then yeah you can put it in a caddy / usb cable and grab your stuff.
If it's part of your motherboard soldered on then nope (MSI probably have ways though) (or if it would actually boot you can run software off a USB to clone the disk.. but yours won't boot so yeah..)
Edited by UNR33L
/remove home made porn before someone else sees it
That stuff is stored on a separate drive
Is that another dock I need, or are they the same pin set up as a normal hard drive...?
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
