First day at work on Monday and caught the train then since yesterday have been driving.... will avoid PT as much as possible. It's funny seeing work colleagues rush out to try and catch the next train as soon as the elevator door opens up.
nice you found a new job? was it you in the IT field as well? :P
not commenting about price..
but a "420hp" manual AWD volvo...damn what a sleeper.
Yeah would be fun. I'm not familiar with the AWD system in them, assuming mostly FWD.
Looks so pedestrian though. Later volvos look much nicer
Pfffft no one can stop the gtst
Got a quote on my dream exhaust tips. I didn't even think exhaust tips could cost that much. Damn VIP tax. My heart and efame says yes, my being a relatively responsible adult says no.
What about a golf GTI with a p plate on it and STANCE?
If I got a golf r and took the R badges off would that count? I couldn't do the stanced thing, I value my guards/guard liners and not looking like a complete tool too much.
Plenty can stop the GTST
It's keeping up that people seem to struggle with...
How does your gtst get off the line? Mine never did get off the line well, turbo spooled and wheel spin followed all the way to 80-100.
Once you hooked up in third it hauled ass. #almost400club
Even a 200kw gtst walked a few car lengths away from me from a launch. Wasn't until I could get 3rd-4th that I could destroy any hope they had.
With WOT it spins 1st unless a grippy surface or a decline to it and the tyres are warm. Still moves along though thanks to KAAZ. 2nd always holds unless it's damp. I don't bother off the line if there's any sort of incline as I can't get enough traction. Not the greatest cars to launch IMO, but NPC carbotic happily takes a beating with slippage to spool the turbo and I've probably done 1000+ launches in the car, so confident I can get the best out of it. My power is nearing the sensible limit for these cars at <100km/h speeds without wearing MT streets or some sort of drag setup IMO. Any more and you start to shift the useable power into higher gears/speeds as you described.
Much prefer rolling drags - not just to take launch skill out of the equation, but my small turbo's E85 midrange is long and lethal. Pulls hard from 70-150 in 3rd - if I can hang with someone until that gear I will usually pull away.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
