On 5/31/2017 at 9:33 PM, dezz said:
Who was it that posted that consumer law stuff about warranty not mattering, product working for a reasonable period of time etc...
What would be a reasonable period of time on an oven (residential)
I actually tried finding this earlier today while doing some consumer readings with no success.
According to one of my ex work team member, she got her Samsung replaced from the manufacturer despite it being out of warranty as there's a standard expectation of white goods in it's life expectancies.
Warranties are separate from your automatic consumer guarantees.  The consumer guarantees which apply regardless of any warranties suppliers sell or give to you, apply for a reasonable time depending on the nature of the goods or services. This means consumer guarantees may continue to apply after the time period for the warranty has expired.
https://www.accc.gov.au/consumers/consumer-rights-guarantees/warranties
Hence it pretty much comes down to what the VCAT mediator thinks is reasonable
In this day and age brands are more likely to fix the issue and bill you lowly or not at all because not worth the negative word of mouth and social media etc.
This... I made dishlex replace my out of warranty dishwasher and give me a free 5 year extended warranty on the replacement.
Just posted a shitty review online and they "came to the rescue"
(on a site I knoew they monitor and always reply)
1 hour ago, dezz said:
Hypothetically, can one claim things like exhaust, tune, supercharger kit etc as maintenance when doing their car expenses for tax purposes?
Toby?
You can claim anything you want
Whether it red flags an audit or not is another thing
Tax is surprisingly subjective - if you can reasonably justify its use then it counts. Can't see a situation that would require those things but maybe the workshop can draw you up an invoice for repair labour without itemising those specific things...
Vehicle has to be used to conduct work though, not just driving to and from work.
I know an old boss used to do a lot of "preventative maintenance" to his Ute, and it always ended up making more power or being less sensible in some way afterwards.
As far as I am aware it was all/partially claimed back in tax, how legit that is I have no idea though.
Yeah well, legit just comes down to justification. The more you claim or the more crazy stuff you claim, the more likely you will be flagged in the system for review / audit (though some audits just happen at random as far as I know). Despite audit being a huge pain in the ass for someone, as long as you can justify with records/proof of your claims then you will be okay / they will only ever knock you back for it if they deem the item unreasonable to claim. If they see that you've made an honest mistake and you don't have a history of bad tax returns they won't penalise you for it.
A tax return is simply saying "I shouldn't have paid tax on this item because x reason". The system sucks, but if you're not exploiting loopholes and all that jazz then you're one of the suckers paying more while those who know the system pay less.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
