Vic Wasteland Thread - 15.0
R31Nismoid
 Share
1 hour ago, Odium said:
Boost or Intake leak = overboosting turbo (correct psi by the time it got to the engine) = overheated turbo = warped / cracked exhaust manifold. My day was over by midday.
No worries about the helmet, never put blocks in place that stop people from getting out onto the track. We've got future track day participants to take care of!
Edit:
Put your
Put your dick on it
31 minutes ago, Leroy Peterson said:
Give it till the 22nd for results... At the moment its happy building solid base, im happy it hasnt gone spastic high and then everyone dumps within 24hours.
Am sad it's doing what it's doing...having bought a house I have no significant monies to throw at it at the moment
4 hours ago, Kinkstaah said:
Only problem with E85 is that it allows you to push so hard on the tune you will break the next thing up the chain as it will never ping.
This ain't so good if you have metal head gaskets, head studs, stronger pistons, rods, crank because when they aren't the weakest point you end up Gregging it™
98 isn't a bad idea as it stops you from going too insane, its a built in safety measure of sorts to make sure the rest of your setup is actually going well. E85 is like fuel-steroids. You can get the 'right' power on 98 in a Skyline at least to the point where everything else starts to become a limitation. You may not get forum and instagram #efame but you will be able to have fun with the vehicle and have a modicum of reliability and do more than hardpark it and fap over a dyno sheet if you go full retard with timing. (or full advance on timing, really)
If you're shifting the performance of your engine into territory that breaks things then that's yours or your tuner's fault, not E85. E85 can take more timing than 98 but that doesn't mean you have to knife edge the tune any more than 98.
This is why you start with E85 and aim for the power figure you have in mind using that fuel. Don't use it as a tool to get another 50rwkw out of an already traction-and-parts-breaking setup, use it to help a smaller turbo give you the same top end power with a fatter midrange, significantly better response, cooler engine temps and smoother idle. Then switching to E85 will be safer than 98. You also don't have to drive the car as hard to get good performance out of it.
Thats the thing, not many people are splitting blocks with 400kw, but if you run as much timing as I was running (which was really wild, looking back) the car will "run fine" and E85 will not give you any indication you are near a knife edge at all.
It will continue to make power and continue to take timing and continue to respond "well" even though you're well into imminent death zone. Unlike 98 which will ping, E85 will give you no such warning.
I now run E85 with basically the same timing (2 deg) as 98. That said my 98 tune is more conservative than most people's run in tunes, so E85 is essentially in there for safety only.
You can do crazy things with E85 (like say, add 15 deg of timing!) but don't. It's best not to make your first point of failure the engine block.
I since compared many maps with many other cars at the Dyno making similar power and ones making much much more.
I now get unreasonably worried when I see -9 setups on GTRs making 320kw on 98 and 390kw on E85, people making 370kw on -5's  and 450 on E85 and think oh damn there's gonna be some issues there soon.
I don't understand this - what do you think split your block if not too much power or poor structural integrity? Pre-ignition? Not all blocks are the same and the N1 was created for a reason. Hamish did a bottom end with ~300rwkw.
People break engines all the time on 98 without warning signs. It's no safer. For reasons I suggested before, E85 is much safer when shooting for the same power level. I'd even wager it's still safer with a bit more power than the 98 tune.
I feel like you're saying 98 is safer because it will detonate before you get to unsafe power levels - if that is the point then it's moot when you can just not aim for the skies and be careful about your power levels.
  • Like 1
We're saying much the same thing I think
Did he do a bottom end by cracking the bores themselves? If so I was unaware. I would wager the amount of timing is was advanced I was basically compressing an explosion. It is possible that the 34 block is just weaker (somehow, it doesnt look to be any different), but there's plenty of people making much more than me out there humming along just fine.
Should the tuner in this case have said "Dude the timing numbers here are way beyond literally any car Ive ever tuned?" instead of "Gee this engine really likes timing"? Yeah probably. I'd wager that won't be said again and the magic E85 envelope won't be pushed that hard again.
I'm not saying E85 isn't safer than 98, it is.
On the same turbo making the same power the E85 is much safer.
Whether going a larger turbo making 300kw on 98 vs a smaller turbo on E85 I am on the fence about. It's really pretty hard/impossible to know.
Being safe and sensible is the best idea. E85 can let you press way further on the same hardware and it is "Safe" in the sense it gives you no indication things are about to go south quickly. You can run 10+deg or more timing and get 70 "Free" KW!
You simply can't push that hard on 98 because the fuel itself is going to stop you, so you can back off at that point (i.e dont run it on a knife edge) and enjoy the car. There is no such thing as a truly free lunch. Run a few degrees of timing over your 98 but don't look a gift horse in the mouth :P
Your own car's performance at 270kw is a good testament to keeping it simple.
If I could refund everything I'd ever done I'd want a LS in my car instead. Make the magic 270-300kw as lazily as possible!
who tuned it?
This isn't a difficult decision. Smaller turbo with E85. The turbo isn't being driven any harder to make the same power, intake temps are therefore the same and less. My 275kw on E85 is the same boost (15psi) as the 252kw tune on 98. Same tuner, same degree of safety in both tunes. And that's just the top end power difference, which is admittedly choked by the small comp housing. Midrange picked up a full 40rwkw, same boost, just more timing. At these power levels the components have been safe for 5+ years of daily stick giving. It's about picking an appropriate power level for your components and finding the safest and most beneficial way of getting there. That is without question E85 and a smaller turbo! Open your engine or aim for the skies and you're asking for it. I think you know this now though, given your retrospective desire for an LS conversion...which I still think could be negated by the tried and true highflowed RB25.
If you continue to tune an RB beyond what the known limits of certain parts are, just because E85 is allowing it to keep going no problem... then you shouldn't be touching a tune file in the first place.
56 minutes ago, Birds said:
 @krzysztof ?
Dude looks like a cross between Patrick and Grant
I f**king spat my drink out hahahahahahhaa
anyone want to buy my rb26?
going a different, torquey kebab path.
Are you building this car for your great grandchildren?
Seems like you havent had a finished car since 1908
 Share
    • I did a pretty ruthless clean up before I left townsville. If it wasn't a part to suit a car I currently have it was sold or binned. I have all my stuff organised in big tubs with lids that stack from supercheap and bunnings depending on who was cheaper at the time. Parts were sorted by either chasis/motor/Fabrication/general/electrical. I have a mezzanine that's 7mx2.3m and all lives up there. Easy to access when needed and out of the way.  I also have the issue of selling and dealing with scumplace/marketbook was actually going to list stuff today but couldn't be bothered as been stuffed around too much. I generally let a few people know I want to off load stuff and people pass it on to others to contact me, generally easy sale and I'm never looking to make big dollars. Rather it gets used than go in the bin. Next clean up will be around Xmas and if doesn't go on the s15 it's going bar 2 sets of wheels.
    • Did a little bit on the V37 today. I bought this LED kit out of the US https://www.ebay.com.au/itm/125953603618. Best I could find online but didn't look great, in the end the quality was pretty much right and it did come with locations for each light including rear number plate and a few spares. The factory owners' manual was also useful with information on where to pop each light out without damage. I prefer the LED look as I use it daily including at night and the LEDs are both brighter and the white light is easier to read with. Vanity mirror comparison, LEDs just look more modern The glove box was the only difficult one (and the only one that was previously blown.....), steps were Open glovebox 50% but not fully open Push up on bottom of the box to unclip it on both side, not screws or pins to remove Remove the top stays at an angle, right side then left, because.... Before dropping the glovebox totally, remove soft close clip on left Then, remove 7 screws to release the glovebox surround Twist the globe holder anti clock to release it from the surround In this case, the LED globe supplied was wider than factory and did not fit, so I ground down each side about 1mm then inserted it Last trick, start engine to check the LED polarity is correct, the globe only operates when the engine is running (whether the box is open or closed) I also moved the 4G booster and wifi across from the Fuga, a little frustrating as I could not find a good Accessories ACC source anywhere in the boot so I'll run a wire from the cabin next time I get a chance. Also, unlike the Fuga the external antenna wire does not quite fit between the rear windscreen and the body so I think I'll have to drill a hole in the roof to mount it. Probably not that interesting for most people so I'll just post once complete
    • Pretty sure I could do but it would need to be exported and reimported as the current import approval is race only. But in practice there are plenty of other practical reasons it can't be a road car despite their potential value these days like stripped interior looms, cage to cut out etc Nah, no mods to it other than updating the roll age to current regs. It makes about 350 (laggy) kilowatts on the N1s at 18psi which is enough to push it around the place
    • This is it, folks! Our final event of the year... The big one, you all know and love - Putty Road! It goes without saying, but this is the biggest cruise in our calendar each year! A nice long drive, with a hearty pub feed at the end! Do you need much more enticing than that!?!? So make sure you wash the car, get your cameras out, block out the calendar, and get ready! We know you're all as excited as we are, so make sure you lock in the details and date below: Date: Sunday 8th December 2024 Meet Location: Corner Windsor Road and Groves Avenue McDonald's / KFC (3 Groves Avenue, Mulgrave) Meet Time: Meet at 9:00am for a 9:30am departure Destination: The Royal Hotel, Singleton (84 George St, Singleton) Map: https://tinyurl.com/saunsw-puttyrd Itinerary: We will meet at McDonald's / KFC on Windsor road and from there will head onto Putty Road. There will be a break at the Grey Gum Cafe (8679 Putty Rd, Putty) which we should reach at approximately 11:30am. For all the Newcastle folks this will be a good point to join up. From here we will continue on to Singleton for lunch. Please remember to fill up prior to heading onto Putty Road. There will not be a fuel stop until Singleton. To those running on E85, Freedom Fuel (old United) at Vineyard on Windsor Road has started selling there. At Singleton there is a range of servo's available including BP, Shell and Caltex. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Back by popular demand - we're lining up another Old Pac Run! Get your cars ready for one of the best night runs on the calendar! So without any ado whatsoever, here are the details for you to save: Date: Saturday 23rd November 2024 Meet Location: Cowan Truck Stop (Pacific Motorway - Refer to Map) Meet Time: Meet at 7:30pm for a 8:00pm departure Destination: Gosford McDonald's (65 Pacific Highway, Gosford West) Map: https://tinyurl.com/saunsw-oldpac Definitely an easy one for this cruise, meet at Cowan Truck Stop and jump straight onto Old Pacific Highway! Final stop at McDonald's which has plenty of parking all around. Please be mindful of the added police presence lately so best behaviour is expected! There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
