52 minutes ago, UNR33L said:
Have any of you fellas actually put a time down the 1/4?
Greg/Birds/Toby?
I know Hame did like a 12.6 or something which is still one of the better times I've seen for a street skyline with coilovers and hellaflush fitment
I'm a god damn street racer
The only slips that matter to me are pink
BorgWarnerlinesaustralia
Toby, before jumping too fast onto the EFR bandwagon, you really look into how much effort it will be to bolt one on to your setup? Do you need a new exhaust manifold/hotside piping/wiring for turbo speed sensors/new oil & water fittings/boost controller.
Greg/Birds/Toby?
Never really interested me to go to the drags to be honest
I think greg went recently? Not sure what his times were
Greg/Birds/Toby?
I did 12.6 with dying AFM's, rubbish BC coilovers and tune that makes more black smoke than diesel Golf.
Digging the MX5 RF
http://www.caradvice.com.au/515564/2017-mazda-mx-5-rf-review-2/
Not sure how someone over 6' would get along with it though
I'm sure it's fun to drive like the 86 in the bends, but if Mazda would just give these cars a small turbo and/or some respectable power, they would play havoc with the 86 and hot hatch markets. It's certainly cheap enough to be a serious contender.
16 minutes ago, HEKT1K said:
Mrs needs a new car
dare I ask wasteland for suggestions?
we're obviously considering an r33, an fpv gs, and an sss pulsar at this point
What about...ah nevermind
17 minutes ago, HEKT1K said:
Mrs needs a new car
Budget? Econobox or premium?
2nd hand mazda3
cheap, now and hold value, reliable and the sportier ones can be ok to drive
so so easy to drive in city as well
4 year old and sub 40K km
http://www.carpoint.com.au/all-cars/dealer/details.aspx?R=OAG-AD-14654399&Cr=1
  • Like 1
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
