Vic Wasteland Thread - 15.0
R31Nismoid
 Share
Headaches wont be a problem as id be just paying someone else to take on the problem :30_no_mouth:
Lol famous last words.
Read through piggaz thread and see the effort he has gone to to get him happy with using the turbo (i know its piggaz, and he has endless cash, but its certainly a lot of work and ECU shit too).
Not sure the details of his build but didn't take Greg long to switch from a gtx to efr timeframe wise?
Doesn't take Greg long to do anything. Especially destruction, that's his specialty. You shouldn't base your thoughts on Gregs experiences. I'm sure he'll tell or has told you that personally.
  • Like 1
Experience must be good if he's willing to sell everything on the R34 apart from his turbo kit :3_grin:
Don't understand how mechanics can delay projects so long and the customer not crack the shits at them, shit wouldn't fly in most other industries.
I'd be picking the car up, cya later going to another shop
  • Like 2
Agreed, if i did that to any of clients they would have left.
Given that to build an engine assuming if you had all parts on hand and were working on it full time would only take a few days, but these cars just end up sitting in the corner for months
For me, it's partly my fault cos I changed a couple of things along the way.
Simple 2 weeks job turned into nearly 3 months and counting. They noticed an issue and spent some time chasing it to find nothing out of ordinary then I decided I want something else.
My credit card's gonna take a beating for sure!
It honestly depends on how happy you are and how much time/money you have.
Anything can ultimately fit and one person's easy is another person's impossibly difficult.
EFR's typically run about ~3000-3200.
Manifold and coating + shipping is $1750 ish. It took 8 weeks to arrive correctly.
External gate costs $600+ unless you find one second hand.
Fabrication work I needed would cost $2000 at Havoc.
You'll need to buy a pod filter, so that's another $100.
You will need to buy lines, GCG sell a kit for $400.
Heat beanie on turbo? $200-400 depending on brand.
Heat shielding for the "heat proof" lines kit GCG gave me? Another $300-350.
Vaccum lines, hose clamps, zip ties, random shit = $100
Tows to and from workshops/fabricator/AC place/To tuner = ????
20 hours of Labor = ?????
Tune = ????? (I DIY'ed mine and got it checked to be perfect in an hour, yay me)
It can get expensive, even if you do all your stuff yourself.
Other stuff:
Aircon line fouled, had to remove it at friends place with hoist. Do not attempt to do this because while we de-gassed the system (and had to abandon the garage, which was large... for 30 minutes, it also snap froze the welding glove being used to do it.
Then when it was de-pressurized, we removed the fitting to take the line off. An explosion happened, green "Stuff" went everywhere and we both held our breath and abandoned the garage again. It ended up costing $330 to get fixed later/re-fabbed and re-gassed.
We had to trim the bolt from an engine mount to fit the manifold too.
VS:
GTX.. buy turbo. Shit, buy one second hand! 3071's are cheaper than 3582's and EFR's.
Bolt on.
Reuse everything you already have. This assume your setup is good and working fine. Given you've kept it multiple years I'm going with yes.
Don't need to sell the 'extras' later. If you aren't DIY'ing the swap, you will save massively on labor.
Keep in mind my car is a 2.8, with a 3076 sized turbo running 17psi with a high stall converter. All of these things amplify torque and response a lot.
Most people go an 8374 with a 2.6 and say its possibly too small, let alone a smaller turbo with more motor.
I would sell my engine bay if someone gave me half of what it cost to do it. There is a vicious curve of diminishing returns at life above 300-320kw, and I can't honestly 'recommend' it unless you have the funds where it doesn't matter much to you, in which case I am more often saying "Buy a golf R with an APR tune" instead nowadays.
  • Like 2
mine was also near on 3 months, but mainly as I was in Germany for a period so we set expectations and dates when I first went in.
we had a time line with payment milestones and regular emails with status along the way
Had car back to them day after I returned (was keeping it at home during the build) and driving it the next weekend.
The thing is, there is no "another shop" to go to
All shops act this way, that would work on these motors.
  • Like 1
Other stuff:
VS:
Bolt on.
My aircon line is redone and re-routed because it blew last time on a racepace dyno. Cooler piping i was planning to get re-done atm, as it's massively long with a million bits that keeps popping on the track.
Yeah agreed what you are saying if i was going to go down a simple route of a simple swap then yeah GTX might be the way to go.
If i went down the path and going yolo ext gate, highmount then EFR.
At the moment its whether or not to put $$ and effort into a car i drive a few kms on the weekends. Honestly if i needed a daily for work i would prob just buy an E92 M3. But atm don't need one and feel like spending money on something #yolo
If only it were that simple.
I contemplated it many times, because 2nd engine job was almost at cost price so they weren't making any money, so day-to-day jobs would cut the queue... For about 4 months.
  • Like 1
I'd rather give them the ultimatum of a end date and if they don't finish on time you're not paying for anything and picking the car up? try the next shop, rinse and repeat.
If they agree on a timeframe they should meet it.
1 hour ago, UNR33L said:
Enough skyline talk.
88e
e85 e85 e85
Smashed avocado
800k etc.
Also birds your GTR should be external gated too <3
Hate external gates
No mod is more offensive to everyone around you and your own ears. Better for power sure, but the evo that drove past the other day and sounded like a cat being mauled reminded me why I don't like them
 Share
    • I did a pretty ruthless clean up before I left townsville. If it wasn't a part to suit a car I currently have it was sold or binned. I have all my stuff organised in big tubs with lids that stack from supercheap and bunnings depending on who was cheaper at the time. Parts were sorted by either chasis/motor/Fabrication/general/electrical. I have a mezzanine that's 7mx2.3m and all lives up there. Easy to access when needed and out of the way.  I also have the issue of selling and dealing with scumplace/marketbook was actually going to list stuff today but couldn't be bothered as been stuffed around too much. I generally let a few people know I want to off load stuff and people pass it on to others to contact me, generally easy sale and I'm never looking to make big dollars. Rather it gets used than go in the bin. Next clean up will be around Xmas and if doesn't go on the s15 it's going bar 2 sets of wheels.
    • Did a little bit on the V37 today. I bought this LED kit out of the US https://www.ebay.com.au/itm/125953603618. Best I could find online but didn't look great, in the end the quality was pretty much right and it did come with locations for each light including rear number plate and a few spares. The factory owners' manual was also useful with information on where to pop each light out without damage. I prefer the LED look as I use it daily including at night and the LEDs are both brighter and the white light is easier to read with. Vanity mirror comparison, LEDs just look more modern The glove box was the only difficult one (and the only one that was previously blown.....), steps were Open glovebox 50% but not fully open Push up on bottom of the box to unclip it on both side, not screws or pins to remove Remove the top stays at an angle, right side then left, because.... Before dropping the glovebox totally, remove soft close clip on left Then, remove 7 screws to release the glovebox surround Twist the globe holder anti clock to release it from the surround In this case, the LED globe supplied was wider than factory and did not fit, so I ground down each side about 1mm then inserted it Last trick, start engine to check the LED polarity is correct, the globe only operates when the engine is running (whether the box is open or closed) I also moved the 4G booster and wifi across from the Fuga, a little frustrating as I could not find a good Accessories ACC source anywhere in the boot so I'll run a wire from the cabin next time I get a chance. Also, unlike the Fuga the external antenna wire does not quite fit between the rear windscreen and the body so I think I'll have to drill a hole in the roof to mount it. Probably not that interesting for most people so I'll just post once complete
    • Pretty sure I could do but it would need to be exported and reimported as the current import approval is race only. But in practice there are plenty of other practical reasons it can't be a road car despite their potential value these days like stripped interior looms, cage to cut out etc Nah, no mods to it other than updating the roll age to current regs. It makes about 350 (laggy) kilowatts on the N1s at 18psi which is enough to push it around the place
    • This is it, folks! Our final event of the year... The big one, you all know and love - Putty Road! It goes without saying, but this is the biggest cruise in our calendar each year! A nice long drive, with a hearty pub feed at the end! Do you need much more enticing than that!?!? So make sure you wash the car, get your cameras out, block out the calendar, and get ready! We know you're all as excited as we are, so make sure you lock in the details and date below: Date: Sunday 8th December 2024 Meet Location: Corner Windsor Road and Groves Avenue McDonald's / KFC (3 Groves Avenue, Mulgrave) Meet Time: Meet at 9:00am for a 9:30am departure Destination: The Royal Hotel, Singleton (84 George St, Singleton) Map: https://tinyurl.com/saunsw-puttyrd Itinerary: We will meet at McDonald's / KFC on Windsor road and from there will head onto Putty Road. There will be a break at the Grey Gum Cafe (8679 Putty Rd, Putty) which we should reach at approximately 11:30am. For all the Newcastle folks this will be a good point to join up. From here we will continue on to Singleton for lunch. Please remember to fill up prior to heading onto Putty Road. There will not be a fuel stop until Singleton. To those running on E85, Freedom Fuel (old United) at Vineyard on Windsor Road has started selling there. At Singleton there is a range of servo's available including BP, Shell and Caltex. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Back by popular demand - we're lining up another Old Pac Run! Get your cars ready for one of the best night runs on the calendar! So without any ado whatsoever, here are the details for you to save: Date: Saturday 23rd November 2024 Meet Location: Cowan Truck Stop (Pacific Motorway - Refer to Map) Meet Time: Meet at 7:30pm for a 8:00pm departure Destination: Gosford McDonald's (65 Pacific Highway, Gosford West) Map: https://tinyurl.com/saunsw-oldpac Definitely an easy one for this cruise, meet at Cowan Truck Stop and jump straight onto Old Pacific Highway! Final stop at McDonald's which has plenty of parking all around. Please be mindful of the added police presence lately so best behaviour is expected! There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
