These landscape gardener kunce quoting my joint make the trade unions look like far left wing liberal f**ktards as far as pay rates go. Wouldn't mind some of whatever drugs they're on..
My backyard... Around $2k in materials, say $2500 just to highlight the ridiculousness of what they want for labour... First official quote was $5k. Dreaming. Second quote was from a description only, $3-6k, but the third quote, which is my favourite........... $9000
Have to call to confirm that the price includes taking the virginity of his 3 centrefold daughters.
Seriously these kunce are off their heads. It's not even technical work. If I can do it myself, you can't ask for $1500 a day labour, for a job that would take 2 days tops, with a straight face.
And $1500 a day is the $5k quote obviously... Not sure where the $9k mother f**ker gets his 24ct gold timber from...
Clearly you mine that timber out of the ground and it requires a lot of processing like any minerals you dig up.
That he can clad your garden in that at such a low price and so quickly is amazing in and of itself.
tradies are f**ked ay
  • Like 3
Under a union, they wouldn't be able to demand such ridiculous money.
Construction industry is still profitable... Because at the end of the day everyone needs to make money. Except the buyers.
Or essential services need to keep running, because they're essential. And people have no choice but to pay it.
But no one gives a f**k about your garden.
I had a similar experience albeit of a far lower value.
Had a broken pipe in the front yard from a tree root... I dug out the pipe and removed the root, plumber came round cut out a bit of the pipe and attached some sort of joinmatron device... 5 mins work... $300
pipe broke again on the weekend (different spot, same reason) so I went to bunnings and bought the part... did it myself in apprx 5 mins
$7
fuckin tradies
  • Like 1
At the moment the people who appear to me to be ripping off the most are specialists in the medical profession.
First visit literally a 5 minute consultation with a few background questions that could have been answered by me filling out a form = $250. Even with $150 paid by Medicare that's extortion of the highest order.
Y'all here complaining about $300 for someone to drive to your house, use materials, fix something and then drive off. But at the same time people here have been discussing hourly charge out rates for IT staff to sit at their desk and take 3 piss breaks an hour for $270+
If it cost $300 to see how easy a job is and what materials to use, so you can DIY it in future... Maybe it's not so bad.
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
