18 minutes ago, Leroy Peterson said:
What sort of issues do people have if plugs too cold? If I run 8's on the street... Would I be better off saving 8's for track days only?
Fouling and yes. BTW, please pay $400 to photobucket so they can show your images.
My plugs were just fouly (which is odd because we had them cleaned when my turbo went on.. maybe a month/1500kms ago), and previously were never that state. My specific plugs looked like this:
So there wasn't a great deal of room for anything when carbon gets involved. But yeah, they were a bit "Carbony" which is odd because E85 generates less carbon and 'fouling'.
But yeah, misfires at idle/very low load and misfires at 20psi, Carboning up, looking rather "tan" or a darker tan than mentioned made me think they were no longer the best option.
All hail BCPR7ES (I bought 18) :P
Crisitunity
There is a Melbourne 88E shareholder meet up tonight, you should go meet some of your new pals.
I picked up 80,000 shares this morning for cheap, so that's paid for by approx tax return.
Feeling even better about my 6.4c sell a few weeks ago now
Yeah good move.
See if it hits a new low tomorrow from pommy influence, but I'm just gonna wait it out. They still haven't used artificial lift yet... 11,000 ft is a long way.
Details? I did not know about it
Another 30,000 for me
https://hotcopper.com.au/threads/melbourne-88ers.3535713/#post-25763781
I picture it in my head a scene similar to ^ that, but I know it would be the complete opposite.
Traralgon Toyota don't carry stock for 2006-2011 Hilux front rotors. And takes them over a week to get stock from Melbourne.
It's probably the most common hilux model in gippsland and a consumable part. They stock the brake pads but "we don't replace brake pads unless the rotors are done at the same time". So why would you stock one and not the other??
I've been to obscure car club meets, motorcycle club meets, LANs with people only known through internet, and the Melbourne screening of The Red Pill...I've learned to expect absolutely anything and the term "all shapes and sizes".
When work throw out over 2 grand worth of old equipment doing a cleanup, I'll take that.. already sold it too, self bonus.
Also had what looked to be Joffa look at my car on Sunday to possibly buy :D
Edited by UNR33L
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
