Wont it just be the same cars that rock up at every meet?
Yep but pulsar hasnt been to a big meet in... Years. Plus gathering of VIP cars who havent seen in a while or freshly imported.
Fair enough we need to do a cruise soon
Pats car should be tuned and done in 2 weeks
  • Like 1
Such a hard life Liam.
Living away from home for 10months starts to take its toll. Lots of car friends to catch up with and a back-catalogue of work to do on cars.
If you want I can hook you up with some cheap Neons to make you feel better? (proper Neons, not that LED pleb stuff)
5 hours ago, Odium said:
Whats next for you?
So after being made redundant 3 weeks ago, i had another department at work ask if I would be interested in working for them.
basically some skills I have that is not replicated elsewhere withing the company that they need.
after discussing with with them, they are building a new role around me and my skill set rather than try and fit me in an existing role.
SO still a little bit of consulting, but more training of others in different offices and having oversite on processes and procedures for some of our partners and offices.
still locking in details but going to be a fun ride
  • Like 2
Basically they gave you a heap of money to change roles within the company.
It's a win for you, bit stupid on their part though.
i've been there for a while,
the IP I have in my head is worth much more to them than my salary...
basically they loose me, they loose near on 10 Mil of revenue stream as they cannot service it.
we have 2 people left who can maintain the product globally and one who can install..
that's the 2nd redundancy that I have come though in better position for.
this one however is all on me, its up to me to either make this role work which has great potential for future, or fail miserably.
and with more exposure, gone from 9 levels to CEO to 4
Reduced levels of management above you can be a good thing.
I have one level and a side step to the ceo, the extra exposure does come with the ability to be able to tell other people to just bugger off and that what you are doing is happening and they are just going to have to get over it and move on, which is great for getting shit done. Though if you have to deal with office politics that's less applicable unless you are at the yolo end of the do I look like I give a f**k scale.
If you are in a non-dedundantable (not a word) job position bringing in revenue to a firm of $10M. Then your salary should be like $5M
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
