I drove a vn wagon that happened to have internationals on it for a while. Towed pretty good, but there was rub as the suspension squatted (pan hard bar pushing the axle sideways). Made an ok tow car with heaps of room for tools in the back.
Edit, forgot CSH.
3 hours ago, HEKT1K said:
see a lot of Maybachs out your way Birds?
Not as many since we signed that petition to stop them parading up and down our street so often
I think I might actually buy these wheels...
https://page.auctions.yahoo.co.jp/jp/auction/u160682457
1200x900-2017090300006.jpg&key=5dbb2312e62968a2317e1c29d2133da1a830ae0ed6939c1243aca19e02da458a
Edit, on second thought it's not that much more to buy brand new and customise. Plus jesse said too much risk for secondhand wheels that price.
When you're sick for a few days at the start of the week, get a medical certificate but the doctor puts the wrong dates on accidentally (forward a week).. give to my employer and they ask me to get it fixed to correct dates.. call Doctors office, wait 3 hours for a call back.. get told yes but I'll have to come and pick it up, finally convinced them to FAX it through.
At what point was me wasting time worth it?
/Friday Rant
Do they make you get a med cert? My workplace never bother with it
I always thought of them as pointless when they can be obtained so easily. My opinion is if you're well enough to get a med cert then you're probably well enough for work. If you're too sick to work, why make you do the unrestful thing and go out to get a med cert?
Because the doctor gets to bill Medicare for your visit to get a note to say you aren't well, the ones where you go into work and then go home because you aren't well and they still want the medical certificate are even more meaningful.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
