1 hour ago, UNR33L said:
Birds when am I rebuilding your PC for special favours?
Surely due for an upgrade? :P
As long as it runs CS:GO I see no need for an upgrade
No time/interest in any other games at the moment
4 hours ago, TiTAN said:
You can run csgo on a potato so you will be fine.
Mine is a shoebox mini itx
Bout 5 years old but still doing everything I need with ease
I had an itx z97 machine. It's now my work pc complete with its 780 ti that spends all its time clocked up and pumping out heat as its an nvidia bug when driving 4 screens that they can't go down to idle, the home machine to replace it was an matx z170 machine and a 1070 as the other one gave me the shits with random bios resets when you turned it on, totally worth the $2500 it cost to buy the new one.
Weird. Computers and components are so cheap these days. Everything seemed so much more expensive when I was a teenager saving for a build.
My shoebox is a tight fit but small desk footprint and about as small a case as you can get with full sized components / decent power supply. Very portable for LANs not that people really do those anymore. Surprisingly doesn't get that hot, except in summer, where the side of the case will burn your hand...and I run a USB fan pointed into the vent nearest the CPU.
Yeah it's a bit like that these days, the hardware is starting to overpower the software / games.
I think optimisation is getting better, because you can really tell an early access games that melt PCs and has prehistoric ragdoll physics.
Also I think graphics manufacturers are focusing on crypto mining hardware rather than backing developers to. Push better products etc
I can't keep up with GPU releases these days
Maybe my time awareness isn't on track, but in the teenage years it was a big deal when Nvidia released any new model like the GeForce 2 GTS. Now the number on the end just seems to go up every other month.
lol reminds me, some guy at work fooled the IT department into building him a rig with a Quadro card saying he needed it for CAD...he had it mining bitcoins 24/7. He is...no longer with us.
It's still a big deal, hell since you got your card 5 years ago there's only been 2 releases (Your 770 > 9xx series > 10xx series) yes they missed the 800 series.
I only just went from old trusty 780ti > 1070GTX last year & still run a 5 year old intel cpu, the only reason to get a newer card these days is if you're running a 4k or 1440p monitor, if you're running a 1080p a potato will suffice.
/nerdlinesaustralia
/nerdlinesaustralia
Those are series though...within them they seem to continuously release an array of cards like 1050 1060 1070 1080 1080ti Titan XP etc.
True there's a lot in the series but that's just like a car having options that are better but cost more. WRX, WRX Premium, WRX Spec R, WRX STI, WRX STI Premium, WRX STI Spec R etc.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
