Huy, I'm sure petrol powered is illegal as far as I know, although no talk of electric bike being illegal.
The pollies must want themselves to look good and encourage everyone to go "green" perhaps?
anything more than 200 watts(250 Watts if Pedalec)  has to be registered legally.
but considering they don't meet bike rego laws most of them are blatantly illegal.
just depends on the cops mood for the day I guess
https://www.vicroads.vic.gov.au/safety-and-road-rules/cyclist-safety/power-assisted-bicycles
oh and 200 Watts is nothing as you can prob guess
12 minutes ago, UNR33L said:
As if they will pull you over though, unless you are doing dumb shit like 50km/h down a footpath
so how most people use them.....
basiclly all drink drivers go out and buy the most powerful one they can.
This guy wasn't a young, he looked atleast 50years old. Could've been a 50year old hoon though as Tracey would report it as.
Question for you IT folks.
So I've been waiting for Optus tech to connect nbn to my new place all day today and they haven't shown up.
So apparently I'm missing NBN box I'm hazarding a guess it's property of Optus?
Had my NBN modem from Telstra sitting in a box for 2 months or so now... Plug it in and they'll switch me over to NBN, which is inevitable, but I'm not gonna plug it in if the speed is slower than my current connection..
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
