Vic Wasteland Thread - 15.0
R31Nismoid
 Share
Just now, Birds said:
Would you have posted if it didn't rise :P
Every stock I've posted has gone up significantly. I wouldn't recommend a stock if I hadn't done my research first.
Cant say I'd recommend 88e though ;) actually it looks like it's found support at ~1.7 might be good for a trade from here...
Same here...but ultimately there's always risk involved which is why no one jumps at it just cause someone says it. Wasn't until people started seeing me profit from 88E that I was able to get anyone onboard for the ride. FWIW when I first tipped it on here they were about 1.5 cents and went on to 8 cents within a few months. Whether people capitalised on that or not is another thing!
I agree 88E has found something of a floor until the next major news. You could just about guarantee a win from buying now and selling at the inevitable ramp up leading into well re-open...if you're patient enough to wait 5 months that is.
  • Like 1
28 minutes ago, Daz said:
I'll be recommending another stock soon (just building a position first :)
I'll follow if I have cash at the time - test your theory ;)
1 hour ago, Leroy Peterson said:
I was browsing stocks and went through 6 pages of VWL and couldn't find it :(
I've been watching MIN with interest lately...
MIN looks like a solid co, probably wait for a pull back :)
I'm trying to find the next company that will go from 1c to 1$ :)
Current state of my NBN / LACK of internet at new house, how long until I can start getting money back off rent for not finishing the houses? A man can only go so far on 4G
22359084_10154945014678779_1077413686_n.
PLS has done some wonderful things. I forgot who tipped it to me but I've had it on watchlist and didn't invest. Now scaling back but has seen incremental consistent increases for last couple months.
Shock works and BC will rebuild their own shocks... Not sure about others.
Also, good luck getting discount rent for lack of services. My heaters been broken since August (urgent appliance needs to be fixed within 9 days) and all I get out of it is the ability to break the lease...
MIN looks like a solid co, probably wait for a pull back [emoji4]
I'm trying to find the next company that will go from 1c to 1$ [emoji4]
Please let me know when you find it. I've got substantial losses from an oil company that I need to recoup
  • Like 1
1 hour ago, Kinkstaah said:
Bilstein will rebuild them, but they're in Sydney and the turnaround time is ~3 weeks during which I have no car..
Therein lies my problem!
Quadrant in Berwick, they're Bilstein dealer IIRC.
Which reminds me, I should ask them if they have softer springs for my PSS9, worse case, Heasmans.
 Share
    • You guys are amazingly knowledgeable and I appreciate it all so much. I’m currently at the local RB tuning shop, getting her inspected and diagnosed, for the t-case debacle and everything else. I’ll keep you guys posted!
    • Like @Dose Pipe Sutututu mentioned, 10W30 on a built motor would not be a great idea. As for the steel wool, we think alike as I went ahead and put SS wool into my catch can as per my above posts.
    • I am going to chime in here and say that is very bad advice for a built motor, making decent power of 400kW+ Especially if the rings have been gapped on the looser side. The more power you make the heavier you need your oil to be to be able to maintain that suspension between the moving parts, if not you'll have journals and bearings making love and grenade a motor. Remember that all moving parts inside the motor aren't ball bearing and are journal bearings and require oil to separate the surfaces from contacting.
    • Yeah I noticed this just now. No doubt she will be running smoother next start😂🤣😂
    • ENR34 manual transmission transfer cases are 33100-23U00 which is shared with all of the R32/R33 GT-Rs and GTS-4s. And the C34 Stagea. Do not bother with automatics, that is a huge effort to swap and the car will be worse for it. And an automatic transfer case does not have the right housing for the shifter which comes out the back of the transmission and goes through the transfer case. I already posted my response on reddit but if you didn't see it there here it is: You have almost certainly damaged the transfer case, the only question is how badly. Nobody can tell you how bad without more information. If you have a giant hole in the transfer case pissing out all the transfer case fluid then you need a new one. If it's not that bad then the only question is whether you burned up the clutches. Drain the transfer case oil and inspect for metal on the drain plug magnet. Small black filings are normal. Big chunks of metal or a ton of black fuzzies not so much. Fluid should be nice and red. Any other color isn't great. If the color is reasonably red and there's not a bunch of clutch material discoloring it or anything like that you probably got away with insubstantial excess wear not worth trying to fix. If you have to rebuild or replace the transfer case keep in mind you have to pull the transmission to get it off.
