Vic Wasteland Thread - 15.0
R31Nismoid
 Share
Which is offset by capital appreciation
But it has to appreciate to double its original value to cover the interest assuming you are just paying the minimum monthly with principal and interest.
As in over the 25/30 year loan period? historically haven't they been doubling every 10 years anyway?
You can only double every 10 years for so long until it's completely unaffordable for 90% of the market.
If all the places that are currently asking 1 million are suddenly asking 2 million you are looking at 10k a month for the repayments and a 200k deposit.
I thought this was VWL, 200k is pocket money m8
Seriously though, yeah I see what you're saying has to stop somewhere but we keep hearing that for how long now? Do people need to wait 10? 20? 30 years for this crash then another 5 for it to become affordable to them?
  • Like 1
4 hours ago, UNR33L said:
Why not just invest in property so you make some money
dezz likes f**king over other shareholders by investing his curse in their stock
  • Like 1
The 10% of the market who could afford in that scenario are pretty much the ones who have been driving it up in the first place. They have disproportionately expansive wealth compared to the rest. I agree it will slow down eventually, but for other variables, like a downtrend in foreign investment. I think majority market affordability will have little to do with it, without government intervention.
Also the more Melbourne sprawls, the more inner suburban properties will push up by virtue of comparison. I think it's gonna take a recession or a serious drop off in the rentals market to stop this train.
As for rentals, there's good reasons to rent, but don't fool yourself into thinking it's financially better over the long term than paying a mortgage, unless your interest is more than a month's rent for the same kind of place (unlikely). You might waste a lot of money on interest but you end up with an asset or at least a redeemable share in an asset.
Disclaimer: everyone's situation is different. Consult your product disclosure statement. Past performance is not a reliable indicator of future performance.
 Share
    • You guys are amazingly knowledgeable and I appreciate it all so much. I’m currently at the local RB tuning shop, getting her inspected and diagnosed, for the t-case debacle and everything else. I’ll keep you guys posted!
    • Like @Dose Pipe Sutututu mentioned, 10W30 on a built motor would not be a great idea. As for the steel wool, we think alike as I went ahead and put SS wool into my catch can as per my above posts.
    • I am going to chime in here and say that is very bad advice for a built motor, making decent power of 400kW+ Especially if the rings have been gapped on the looser side. The more power you make the heavier you need your oil to be to be able to maintain that suspension between the moving parts, if not you'll have journals and bearings making love and grenade a motor. Remember that all moving parts inside the motor aren't ball bearing and are journal bearings and require oil to separate the surfaces from contacting.
    • Yeah I noticed this just now. No doubt she will be running smoother next start😂🤣😂
    • ENR34 manual transmission transfer cases are 33100-23U00 which is shared with all of the R32/R33 GT-Rs and GTS-4s. And the C34 Stagea. Do not bother with automatics, that is a huge effort to swap and the car will be worse for it. And an automatic transfer case does not have the right housing for the shifter which comes out the back of the transmission and goes through the transfer case. I already posted my response on reddit but if you didn't see it there here it is: You have almost certainly damaged the transfer case, the only question is how badly. Nobody can tell you how bad without more information. If you have a giant hole in the transfer case pissing out all the transfer case fluid then you need a new one. If it's not that bad then the only question is whether you burned up the clutches. Drain the transfer case oil and inspect for metal on the drain plug magnet. Small black filings are normal. Big chunks of metal or a ton of black fuzzies not so much. Fluid should be nice and red. Any other color isn't great. If the color is reasonably red and there's not a bunch of clutch material discoloring it or anything like that you probably got away with insubstantial excess wear not worth trying to fix. If you have to rebuild or replace the transfer case keep in mind you have to pull the transmission to get it off.
