88E touches 2 cents. Are we seeing early/slow start to ramp up or just some recovery?
Good start to my hypothesis about it being a guaranteed win for the 1.8 cent buyer
Updated all my apps for the first time in many months. SAU app takes 3mins to update Participated thread list and fb messenger app struggles to show gifs.
Never updating social apps again.
Bitcoin gonna break AUD10,000 this week.
If we convert those member join dates into prison sentences, Ric and I have done time for perpendicular vehicular homicide, Hamish is in for manslaughter and Patrick is a pedophile
  • Like 2
10 hours ago, Leroy Peterson said:
Will spend my bitcoins on alt coins before November 16th (the split). Then try and convert back to coins when it dips. See if I can pull it off.
split cancelled :( price hit $10kAUD then retreated. other coins going up in price. oh well.
On 11/6/2017 at 3:02 PM, UNR33L said:
Stock trading guys, keep eye out for this:
http://www.afr.com/business/health/biotechnology/telix-pharmaceuticals-snares-big-backers-20170915-gyiccx
http://www.bioworld.com/content/aussie-radiopharma-firm-telix-opens-largest-biotech-ipo-asx-csl-0
The Mrs works for their partnering companies and it seems the directors are investing BIG money before it goes public.. might be a good train to jump on board. I've got no idea as haven't looked into it enough but thought i'd mention it.
https://hotcopper.com.au/asx/tlx/
They're investing big because big investment groups have jumped on board. Making it public they get a huge sum of cash. I'm not familiar with what usually happens with a new IPO starts. Will keep an eye on it though.
As of this morning I won some Vertcoin and Ripple coins. the system seems simple enough. The system also seems very different from what the purpose of the currencies actually are! But open market is open market... just we all buying coins with no actual purpose other than to trade. At the moment its like a self-fulfilling prophecy.
What disturbs me about Bitcoin is how fast it's growing and how easily it could crash, all being hedged on future adoption
It seems to benefit a great deal from original and the best / household name syndrome like Google
But also seems to be the worlds biggest upramp
Good luck picking when to get off that train
    • It's not a dumb question. I was circling this idea myself. User error is always possible!
    • Nope. The seal is in the drive. A new cable would just fill up and continue to convey oil to the speedo head. To check if this is what is happening, take the cluster out, dismantle the speedo and have a look. You probably don't even have to dismantle it. If there is oil coming up the cable, the drive into the speedo will be grossly greasy. I had to manually (and delicately) clean the gunk out of my speedo.
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
