there was a blanket ban on them, for a while but they are starting to get wise, we were in talks with some-one who does drone following for arc as a friend of a committee member, he has all permits, but could not work out dates.
Am hoping now that things like rally V*'s and such use them that it becomes more frequent and easier to get. same as drone licencing from CASA is getting progressively easier.
3 hours ago, UNR33L said:
usually I use my motorbike Helmet & gopro mount works well get to see what the driver is looking at cones / direction etc.
Has anyone tried mounting the gopro right in front outside the mouth part?
thats exactly what I do, and its by far the best position.
basically this (not mine but similar setup):
  • Like 1
Why not dash cam it? Even using a shitty ass $80 dash cam from 8-10 years ago picked up pretty good view and sound for me. I would think anything modern be very good quality and bonus you can just leave it installed and use as a dash cam...
whilst the res of those is great the ones I've seen have been fairly slow FPS (prob for space) where as the dedicated ones are much better. (not looked for a while however)
will install one in next car, think I could do a whole dash cams aust streams just from my 1 a week trip to work
HUme hwy brings out the worst in people
There was a really good dash cam a couple years back, pretty exxy but it was made for racing - had awesome quality video and GPS logging for lap timing with 10mhz(?) signal.
6 hours ago, Birds said:
next moment car gets broken into to steal dash cam....
I remember having detachable face stereos worth less than a decent set up dash cam, or mobile phones that every-one was scared to leave in a car.
now throwing man $$ to something very obvious to outside folks.
  • Like 1
Some of them remove pretty easily with their shoe mount, I wouldn't want to have to screw it off every time
Yeah that's a bit of a worry, $500 item sitting in plain sight, who can be stuffed removing it every time.
Those Sony XPLODE head units were the bomb, all dem bright red LEDs before RGB came into play.. the double dinn Pioneer head units were for the rich kids
Edited by UNR33L
  • Like 1
Saw late 80's hilux on city link this morning, dints and rust on every single panel. Removed rear light globes so only the brake lights work. No lights illuminating the personalised and unreadable numberplate. Full dodgy, escaping tolls and speed cameras.
Has primo quality dash cam hooked up and iphone holder for maps. Car was a wreck, maybe waiting for perfect insurance claim.
  • Like 1
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
