2 hours ago, UNR33L said:
Yeah that's a bit of a worry, $500 item sitting in plain sight, who can be stuffed removing it every time.
Those Sony XPLODE head units were the bomb, all dem bright red LEDs before RGB came into play.. the double dinn Pioneer head units were for the rich kids
How is it different to putting a GoPro in and out? The dash cam is easier to remove
Cams are that cheap and common these days that I don't think they'd be a major haul for break ins. The kind of people breaking into my car aren't doing it for the contents anyway, just a joy ride.
Still have a brand new one of those Xplode head units sitting in my room at mum's house...motorized face and shit lol
Wasted Christmas present
It isn't, screw putting a go pro on as well every time you drive / ride lol
Off topic: mate of mine waiting to settle for 125-700k apparently, from a motorbike accident some lady smashed into him broke his arm now having problems with it even though it happened 6 years ago..
tl;dr someone hit me with their car
This looks pretty bargain - cheapest way into a GTX1060 on the go - what are ACER laptops like? I know Dezz bought some horrid laptops but can't remember brands other than MSI
https://www.harveynorman.com.au/acer-predator-helios-300-15-6-inch-gaming-laptop.html
Horrible laptop is still going strong, the issue was an old modem not being compatible with the newer wireless card technology. Upgraded home network, problem solved.
7 hours ago, Birds said:
Bullshit^
Here's what you're gonna do...when I hang up you're gonna call me back and say the complete opposite of everything you just said to me
I rarely agree with anything Hamish says, but hat is spot on. KK are rubbish. fresh donut king cinnamons any day.
  • Like 3
Daniels donuts way better than KK
Used to live so close to Daniels when I was in Clayton, probably one of the big things I miss about the area. RIP :(
That laptop isn't bad for the price, rip out the shit 1TB hard drive and put a SSD replacement in as well.
So 4 months and they still haven't sold the place we are renting, hopefully they say f**k it and keep it for a bit longer. Asking way too much 890k for a 3 bed townhouse, yes its new but everything cheaply done and nothing special.
Edited by UNR33L
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
