People like mudflaps the same reason they like flared guards, the same reason they like vortex generators, the same reason people like wangs and motorsport-looking fitment,
Function IS form.
Whether people need it or use it is another story
88e is still alive?
inb4 SAU 2038 still talking about 88e announcements @3c [emoji14]
That will happen.
Because this thread hasn’t been renamed to 88e thread [emoji14]
Metec results are out
19th overall, not bad.
As suspected went well on the skid pan (3rd I think?) but not as well on the open courses not wanting to bin it :D
Edited by UNR33L
yeah the Pan results were the last I entered,
you were not looking good prior to that...
that said Pat WTF....the only time out of the bottom 10 off the pan was when I said I wanted some Neo Limiter skids...
Ended up higher than all the mates I knew that had entered, so it's something I guess
That being said having a dedicated track car would make you so much more competitive not really caring if you run wide etc.
Good day overall, apart from the waiting :D
Haha 370kw with tyres I planned for skidpan use-only and not a whole day of wet track sprints [emoji29]
After I went sliding onto the grass, I saved the fun for the skid pan
11 hours ago, Rekin said:
Haha 370kw with tyres I planned for skidpan use-only and not a whole day of wet track sprints emoji29.png
something something i told you something something tyres
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
