13 hours ago, Rekin said:
+1
I need to rewire the whole loom, now that it’s running fine, but the effort required is too much.
Diff oil needs changing, dash cam needs installing, AFR gauge needs calibration, sound system to fit etc.
Never ending & weekend-time is becoming more valuable to be spent worrying about problems lol
Yup this is why now i never do any work on the car and pay someone else to do it
I also use Airtasker for gardening lol
  • Like 1
44 minutes ago, Leroy Peterson said:
At least with the subaru everything is bolt on available and the car hasnt changed much since 2011 lol.
Wheels are def next for it, not a fan of the oem ones. Just dont get gloss black please. Gonna keep the same diameter or reduce 1"? They look a bit rubber bandy at the moment
Just realised you were talking diameter.
I'm still deciding, I kind of want to keep the same size 19s the only advantage of 18s is more tyre choice.. but then I feel downgraded ?
I'm still deciding, I kind of want to keep the same size 19s the only advantage of 18s is more tyre choice.. but then I feel downgraded [emoji14]
Wow. Those nitto invos are only ~$200 a corner.
RIP called the local Cobb tuner only to find out he has sliced his arm open and had it operated on yesterday.. out of action for who know how long!
Means I have to wait or go to Sunshine, da west side brah.
50 minutes ago, joeyjoejoejuniorshabadoo said:
Lol I haven't given a shit about cars for years now. I ride mountain bikes which satisfies the need for constant modifying however
Cold hair intake amiright
  • Like 2
  • Haha 1
Could probably easily spend similar amounts of money though
  • Like 1
18 hours ago, Count Grantleyish said:
Considered other tune files like Ecutek or something?
Some of them do that, I think Trent does etc. doesn't help me when I've already got the Cobb access port for off the shelf maps installed.
You chose Cobb for its e-fame?
If you do, it’s understandable.
Imo the whole point of buying a new car is that you shouldn't need anything more than off the shelf maps, if you want it wildly modified. Why buy new when you can get something older, spend the same money as the new car and get way more performance.
  • Like 1
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
