Bet that 25 we ALL suggested is looking pretty f**king good right about now eh
Never understood the fascination of the 2.6 engine over the 2.5. About 60 cc difference i think
The talk around people who have em you would think the difference is monumental
  • Like 2
This. But didn't you put a 26 in yours?
The 25 is the superior engine in almost every way save for .1 litre displacement
Not even the throttle bodies and no crossover pipe can save it from that debate
But people want it because GTR engine, even though putting it in a car where the engine is the only thing GTR about it
Stock RB26 still be faster than your engine Tony :P
Lel... nah, one of your wife's mates punched out a woman because she told him his behavior was not appropriate infront of children.
Right hook to the face.
Aaaaaaand everything i deplore about AFL is confirmed... again
One drunk kunt hits a chick and the whole sport is a write off.... Sounds a lot like the cops you whinge about harassing import drivers..
And if a woman wants to hit a man she better be prepared to get hit back. f**k all that 'you never hit a woman no matter what' shit..
Before you all have a cry, read what I wrote. The chick in this case didn't hit him, going off the footage, so he shouldn't have hit her, but in cases like those bitches in America on the bus/train that started laying into the guys believing they wouldn't get anything back simply because they were female. Well if you want to act like a complete skank and beat on someone like that (and don't for a second think she's a woman she can't have done much damage) don't act surprised when that person, who is probably stronger than you, knocks you the f**k out.
  • Like 1
agreed 100%
there no excuse to hit some-one but you start it expect retaliation.
Yeah I agree regarding getting wailed on by a lady and feeling like you can't defend yourself. But y'know, Australia is against violence against women, but men can't be schooled to not hit each other cause you know, instinct and Shit.
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
