Well Dezz the reality is that even slashing their pensions and entitlements etc would make a minuscule difference to the overall books. Not to say I am for it just the reality.
The unions on the other hand butcher and stifle growth through onerous conditions and wage growth expectations (demands) ie train drivers .. What next $200k a year? Gimme a spell.
Edited by alr33x
Cut the fkers, maybe then we'd have politicians who want to be in the job to make a difference and not for the pay packet / pension / expense claims.
It's really hard to buy that a politician is any way in touch with most of the population when they live within the upper 10% of it. I believe they start off with good intentions, but the things they do to get office, the deals they make and the souls they sell change them into power hungry ego tripping cretens.
  • Like 1
You'd have to be pretty stupid to take a paycut to save your employer money when they could just sack you whenever it suited them
Because companies just sack people for fun and no other reason
Anyone truly worried about getting sacked should consider that they are perhaps a dud
  • Like 2
+1 have been involved in the selection of people to sack due to budget cuts. It's the duds which let go first. (Or who the manager doesn't like) #workpolitics
Nail on the head
Yeah but on the flip side a majority of American politicians are extremely wealthy and the system is no better
Not sure what the answer is
Yeah, i get that... royal kingdoms of years past being an example... my point was it will always fail when a nutcase get in... (or the guy thats in becomes a nutcase)
This. But didn't you put a 26 in yours?
The 25 is the superior engine in almost every way save for .1 litre displacement
Not even the throttle bodies and no crossover pipe can save it from that debate
But people want it because GTR engine, even though putting it in a car where the engine is the only thing GTR about it
Nah still have a 2.5 Neo motor
Stock RB26 still be faster than your engine Tony :P
Probably since its not really working at the moment :(
Was curious mainly cause my engine exploded, and I know yours kind of did, and kind of went back, and kind of has issues, so I have a vested interest in your car also working right ;)
Getting flex fuel right though, man... requires mastery and a lot of patience, or a f**k load of money paying a tuner to have a lot of time to spend on it
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
