Was curious mainly cause my engine exploded, and I know yours kind of did, and kind of went back, and kind of has issues, so I have a vested interest in your car also working right ;)
Getting flex fuel right though, man... requires mastery and a lot of patience, or a f**k load of money paying a tuner to have a lot of time to spend on it
Hrmm my engine has been fine since the original build, just the e85/clogged injector sorta screwed me over
Flex fuel who has done it with Trent? Pretty sure he does tunes in his sleep. the quote from Trent wasn't much and i think he'd only take a day or two.
Oh well probably still stick with racepace in the future though
Housemate did it with Nistune with Trent - Very very good on his SR
I did mine there but my 98 tune was more of a "emergency use only with a bit of spirited driving", but even then it needed a lot of touch ups, hence the whole "it takes a shitload of time to get right"
Cars will run well on non-optimal settings though, Birds saying dat power FC swap after half/3/4 of a tank of E85? makes me really uncomfortable but I'm a stickler for that kind of thing as well, I break all the things
still doing track day?
yes
That'll be cheap....
of course. but the thing is, i got shafted, the bloke that put my motor in, who i paid to check every seal etc obviously didnt check shit so half the f**king motors leaking
I would assume Chris would put in a safe tune so Mohomo can do the track day
looking forward to see what times he can do
285rwkw safe tune. thing f**king hammers
still think should have run a TD42....
ROLL COAL
Then I say hello GTR drivers seat while the R is getting assembled...this should help with helmet clearance when I track the GTS-T! Assuming I don't fly into the back seat...
Any idea how much lower it sits?
NATS?
Flex has one advantage over non, so weigh it up against that I guess: Put in any mix of fuel and thrash it on that mix.
Every other situation can be accounted for and overcome with the two map switch, using a small amount of forward planning. Going away for a trip? Convert to petrol 1-2 weeks before it when your tank gets low enough or simply take laptop with you and when the tank gets low enough (10 litres or less) fill up at the next servo. You can even give it shit with this mix if you have a safe/rich 98 tune.
That's the only time I convert back from E85. Every other time you'll want to run it fulltime anyway for dem power benefits and United servos with E85 are everywhere now.
Yes, but you're assuming on the mix. An empty tank is never a fully empty tank. I've run a tank of 98 down to the light and filled with e85 and had something like 58% Ethanol content.
I've also at times forgotten to plug back in my E85 sensor, and cruised down the street with a 19:1 AFR with E85 in the tank. The car however, felt fine. Me being me, I would go through at least 2 tanks of whatever fuel before I even decide to get onto any boost after 'swapping'. But my car will probably break down between the two tanks anyway
Gear knob felt noticeably higher afterwards, but I could still see over the steering wheel lol
  • Like 1
Trent was the first I know of to do flex fuel (chinny's 34R) and has done a bunch since.
Decent amount. Much better driving position for tall people... you know... from the back floor...
so only one of the VIP guys got into 100MM (Nick of course, being the only one bagged and able to sit on the ground currently), which is good as it saves me forking out $60-70 for a show'n'shine.
also means i have to go all out dress-up at Sandown on saturday. not enough time to get a decorative exhaust tip or mount side skirts. oh well.
I can't blame you for doing that with your car and your luck
But honestly, either I have the worlds safest E85 tune (I am only 20rwkw gain in the top end and 40rwkw in the mid), or a healthy ass engine setup. When I switch back to E85 it's usually 50+ litres that goes in and whilst I don't redline the thing on that tank, it definitely gets boosted to full boost no problems. This is why I'd never flex fuel my current car. It would take some seriously diminished E85 locations or massive pride rises in it for me to flex.
You're never going to have an issue with fuel while running a safe, static E85 tune, because all it will do is run richer by way of the extra fuelling and richer mix.
Fk I wish there were pictures of you driving around like a Mexican
Ah fair enough, yeah mine is just little touch ups here and there kinda
He said my 98 tune was perfectly fine for the street thrashing, but for track e85 is optimal
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
