Are these circuit familiarisation days worth it the day before track days?
And by this I mean in terms of how fast you're allowed to "familiarise" yourself, if the passenger laps are limited in speed and what etc. How much time on the track? Nearly doubles the price of a track day but curious on the worth of it beyond getting to know the lines.
So pulsar basically has 3" intercooler piping everywhere except straight out of turbo and a 0.5m section after the intercooler cold side. (Intercooler and intake are 3"). Would it be worth changing that section to 3"? Would it be a bottleneck or just a source of heat? If manifold pressure is 20psi for eg, then this section would be higher I guess.
3 inch will flow 600kw, sounds like you are going overkill to me...
LAG for days... :P
Sounds like a massive waste of time/money to me.
First session is always a bit slower anyway... track may be a bit slippery in the early morning, your tyres aren't at the right pressure / temperature. So I always use the first session to cruise around and warm things up, get re-familiar with the track and then I come in, immediately check tyre pressures and set them to where I want them to do... Then Session 2 is my first actual fast one.
Might be worth going along to a day like that if it is 30 cars and heaps of track time, or they have professional instructors who can show you the fastest lines
Have spent over $1000 on artwork over the past couple of days. Getting old. #houselyf
Poor r32 looking untidy
How's houselyf for you Leigh? More interested in furniture than car mods haha
SELL ME THAT CAR
  • Like 1
Haha yeah I went through the same phase, I just spent $143 on framing a few pictures from a Phillip Island track day to put in my 'study / mancave' alongside my Lorenzo / Hayden frames..
Got a Joker canvis for my HT room recently too.. #housemods
Also dat furniture $$$
Trying to afford/justify a cat back for the car atm..
Edited by UNR33L
  • Like 1
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
