Birds, on 14 Oct 2015 - 2:42 PM, said:
Auto / manual
Does not compute, does not compute
Was SST though
Also drove housemates SR20... also does not feel laggy.
Honestly kind of made me think the RB25 is pretty f**king laggy for the capacity, given how good other 2.0's actually seem to be relative to it
Felt a bit like the 2.5 Subaru engines being 2.5 to keep up with Mitsu's 2.0
You have a huge turbo on yours though, don't you?
Can't compare response with nearly twice the power
After driving a slightly Modified 8MR, then getting back in my car, off boost wasn't as annoying for me anymore
Was SST though
once im running boost ill take you for a spin. not sure what you interpret as "lag" but big cams certainly hold things back (until on boost...)
driving car home tomorrow :) been a busy few days on it.
that's cos it got outsourced to the singaporeans, same as citylink.
If there's one thing Singaporeans can do, it's build shit
Using people from the rest of the world
Car related question: do I need gasket sealant to install a catback..? or is it recommended..? or just the gaskets good enough, keeping in mind it's a cheap-ish x-force exhaust..
Edited by UNR33L
net glitched out.
got locked out of our NAB business account.
account is in my name and partners name.
nab acknowledges that i am also on the account, wont give me a new password.
partner is currently OS.
daf**k man.
Couldn't tell you what to do without being at work. End of the day it will all come down to what paperwork you signed when you at the account up initially. If it says both ID's required then you's in for a bad time
Not really that huge given the difference in displacement, but I guess its gonna be noticeable at under 100kmhs in any case.​
260RWKW in a SR20 did NOT feel laggy. It was enough to kick the back out at 30kmh in 3rd at part throttle, boost is pretty much on any time you hit the throttle.
I guess it depends on how much powarz you are making on your SR20, the example I was using is a GTX2863R at about 260RWKW, but at the same time feels like its the sweet spot, would lack traction at much more than that, and just get lag for no real benefit.. in that specific setup.
it is entirely possible my car is a complete clusterf**k nugget
At least you're out of the way for Headspec to start on mine now, i.e replace a head gasket so I should be good to go in 2021.
lol. yes it did take a very long time for me to get my car in there, but was kinda my fault it took a good part of a week to get it out the door. thank you for your patience. (but also keep in mind ive been on the imaginary waiting list for many months).
similar power on same-ish turbo. but big cams, FWD and less weight. traction only an issue if driven like a muppet.
dont give up on car just yet, may need an open mind to overcome some gremlins though.
tbh I have ordered the gasket and studs but they haven't arrived yet. Will be keen to see what actually happened, as it was picked by my keen spidey sense of "SOMETHING IS NOT RIGHT" which has been honed by destroying everything over the years.
I may end up going a 1.06 rear "just because" because HS believe that I've lifted the head due to backpressure, even though you'd think a .82 on a GTX35 would be enough to get the air out.
But then again, who knows what'll happen once it comes apart. I will be pretty keen to see what studs were actually in the engine, if they were ARP2000's after all then they were under-torqued on the blueprint.
If its only that, I'll be a happy f**kin camper lol
from what I've heard (and its all second-hand info if you know what I mean), the last motor was bit warped and you're running stock head gasket on a big power/boost 2.8 setup? i know its a metal gasket, but thats a lot of boost. Tony runs factory, but he's got a big-ass turbo with less boost.
there is talk of an underlying issue that hasnt been addressed causing this warping. wont know till its torn apart.
As it should be
And greg pls...no car is kicking out at 30km/h in 3rd gear without a clutch dump on shot tyres in the rain!
There's nothing magical in the Jap 2 litre engines, unless very high comp and E85, that's going to make them more responsive or less laggy than a 2.5 with similar top end power. I'm yet to drive one more responsive than my 2.5 that doesn't die in the ass after the mid range cause of its tiny turbo...happy to be shown otherwise...
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
