Bottom line: whatever you do to a 2 litre you can do to a 2.5 and enjoy approximately 20% more of it
There is no replacement for displacement (within reason)
There has been no amazing production engine development for bottom end torque since these engines were created; VVT is as good as it gets for broadening the power band, but that is a mid-top end power increase.
Greg listen to Michael not Frank when your building your engine. I remember when he built it he mentioned there were issues with it that needed addressing
What part do I run factory Leroy?
Also Evo X, short gearing SST, pretty much no lag and always on boost. Pretty much 6th gear at 80km/h
I do listen to Michael, who pretty much agrees with anything we've thrown out there. Yes, a GTX3076R in a .82 is small for a 2.8, but it isn't small to the point where you smash an engine to pieces... people run them on Supras. (went bigger anyway)
Birds, on 15 Oct 2015 - 11:55 AM, said:
Is that my dyno plot? In depth research lol
My setup is 16psi throughout, with a laggy IWG highflow inside a Nissan comp cover for stealth. The SR, with what sounds like an over-boosted small turbocharger at 22psi...is not really impressing me. It would be a quick car, but put a smaller EWG turbo on mine that doesn't get choked in the top end...it'll move the graph down 500rpm off the spool and make much the same power as both of us up top, albeit not as stealth.
It is your dyno plot, but this SR is also internally gated, low mounted, stock manifold and bleeding off to about 16psi up top. It is a very similar setup man.
It may have been 2nd gear it decided to slip around on, but it was very much under the (50kmh!) speed limit on a side street, rolling onto boost when it happens, very very very long way from any clutch dumps!
My point was is that "if you have 2.5L you can't ever go back to a 2.0 in an evo or SR" and I reckon nah man, the difference would be miniscule given the cars these engines are put in. I reckon they make more power/torque/whatever per cc than a RB does :P
We'll have to agree to disagree...I haven't driven a 2 litre that's wowed me down low and held it through the rev range yet. Evos especially with their weight disadvantage - feel like you have to give them heaps to get them moving, and a Skylines are bad enough for that.
Stock internals (besides springs/retainers) k20 e85 prescision 5831 .63
14psi 300kw
17psi 320kw
Since its 'MURICA take off 5-10% because 'MURICA.
Too bad it wrong wheel drive.
still respectable is it not, inb4 gtfked honda boy
12080330_931001243645927_881850058088859
inb4 someone says that shit will blow up, this pretty much standard for a turbo k20, 400-450kw is when it gets unreliable with stock motors, but still easily achievable :|
No one is talking peak power... Talking about lag/displacement/driveability
Put a big turbo on anything and it will make big power. Just lot of money and go fast bits making it happen
From what i've driven, high comp makes the boost instant, full song around 4k till 8-8.5, which is alright with hondie ratios
Car is 1ton like pulsars, 2L plentyful off boost, gets off line really easy, but then we're drifting off to the silvia vs skyline chassis hear
From what I'm seeing in that graph, definitly not peaky, lots of usable power
Referring to the 300kw one above, is similar set up to mates integra.
Im just bored ok
felt like spamming
f*k yas
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
