Alex REA,
is your A5 a 5 door?
is it diesel?
if you answered yes to the above, please also answer the following question.
Are they any good?
Is there 3 seats in the back?
Lol his A5 WAS a piece of shit... like everything made by Volkswagen
  • Like 2
Alex REA,
is it diesel?
Are they any good?
I had coupe 3.2ltr 6. It was a heap of shit soooo many problems got rid of it after not even 18 months.
Good looking cars, and chances are I was unlucky just a lemon so to speak as friends had no issues with theirs.
Edited by alr33x
Shoulda bought that GT mate ;)
Probably although the Lexus is suckin the juice my kind of driving is not conducive to an engine larger than 4cyl lol
Current tank 15.3 ltr/100km so far
Dat stop start lyf
Dat stop start lyf
Meh.... that's 90's Jap sports car consumption. Preaching to the choir in here yo
Truth. Doesn't bother me much it's quite good it's just when I do a whole week with no one journey more than 3kms lol
Dat stop start lyf
Yeah mines about 15-16 as well, I only do like 10,000km a year so doesn't fuss me that much.. cars just ticked over 43,000
ok so, seems I'm not on Public transport to work..
other than just don't, hints?
do people watch tv on their tablets and such? books on phone?
how does one make the mot of a bad situation?
You really just asked for hints of how to spend time on public transport?
that and what most other people do?
or hints on how to make it easier?
not caught PT regularly for 15 years and that was a short tram ride
Successful PT passenger
- earbuds with no music on so you can hear what people near you are saying about you
- one way sunglasses so you can study everyone else
- hoodie so you look less like you have valuables on you
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
