got a dude keen on my ce28ns...
have the potential to make a 75% profit.
do i take it and get these in silver?
http://www.importmonster.com.au/shop/product_info.php?products_id=2102
stock dc2r for daily, ek going under some works but will take a while since most of my money just went into holidays. Graduate end of this year :D
:rolleyes:
Got a job lined up yet?
what you planning to do with the ek?
would have though ek daily dc2r track/mod car lol
I just think they look too fussy on older cars on a newer WRX or VW maybe but still think chunky 5 pokes where it at
Typical time waster:
Is chasing a turbo manifold for turbo conversion, gave him a price, said he was happy. He'll be keen next week just need to pay some bills. Message him a week later "sorry I sold my car".
f**king wankers
Got part time atm between graduating and finding full time. Atm in process of doing interviews for a grad position somewhere
chucking a k24 in the ek, stock dc2r is a nice daily, comfy, handles amazing, cheap on fuel, good power for daily duties. And it was cheap cause its got key marks all over it, everything else is ballin
ek will be that half track/weekend car. then hopefully find me a crx as a track hack like billy (blags) is doing atm.
then dc2r gets sold for something normal for super cheap fuel/insurance ect
edit ek is too far gone to be a daily that i can treat it as a shitter
Have you considered buying a man's car?
VB is a strange beer, it exponentially gets better based on how hot the day is, and how cold the beer is.
This is an undisputable rule of the universe, no matter how uncomfortable.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
