Yeah I think so, looked that way. But surely it's a weight saving.... Everyone else may as well do it
yeah the evo I was looking at a week or so ago had that done.
the small amount of weight saving there was massively offset for the piping and 3x the amount of coolant. but the extra coolent did also mean less air flow was needed for a single lap dash.
Geelong bitter is where it's at.
Don't care how bawler you are, $4.50 jug is hard to pass up. Sometimes you could taste a hint or cornchips
Many happy night in the 90's from GB dollar pots
That's because Singaporeans ARE people from the rest of the world
Were*
Now new China
This. PRC's are takin over the island. Even OG SGers are gettin all xenophobic about em.
We'll have to agree to disagree...I haven't driven a 2 litre that's wowed me down low and held it through the rev range yet. Evos especially with their weight disadvantage - feel like you have to give them heaps to get them moving, and a Skylines are bad enough for that.
A45 AMG. 2L. Froff.
Lol his A5 WAS a piece of shit... like everything made by Volkswagen
Eat a bag of dicks kent.
This is likely because of the cornchips eaten by the person whose beer vomit they recycled that shit from
Guess the unwashed masses need to think they can eat like the rest of us.
IN all seriousness Katie wants to go but I want to hold off for 6 months, can see the menu being "fine tuned" a few times early on till they get there.
not that every review won't be full marks no matter what they serve up...as if Heston came up with it and must be smarter than all us so lets give it full marks so no-one clicks we did not understand it.
SG taxi drivers got a mad hate on for them even though they are half their fares. SGs have been forced out to the fringe. One driver warned me it could happen to Australia too
Then I warned eastern suburbs Melbourne and VWL and yeah...too late. Rekin's ego suffered many dents at the hands of 18 year old cashed up Chinese princesses owning the auctions.
  • Like 1
Understand food lol...that's what's wrong with all you fine dining cocksuckers...does it taste good? No? Then its shit food. f**k the experience.
China will own Australia soon enough so we'll be the ones invading what will be their country
  • Like 1
Now now, no need for all that anger just because you don't understand
I mean the generation 0-40
Though I think it's a societal shift brought on by technological change and cheaper material goods rather than isolated to one generation
Even my 59 year old mother can't wait for the next iPhone...had to get a 6S to replace her worn out 6...from 12 month ago.
It's taking a holiday together for the last time before your life changes for ever. Not to mention the fact that you won't be able to have one for a long time afterwards
Not a difficult concept really
  • Like 1
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
