I've decided housing affordability = directly proportional to Alex's financial position
Well it goes a little against the grain of what your saying though doesn't it.. Cos if houses were more affordable.. Then more people would buy them so I'd make even more money.
Hrmm...
last realestate q for the day.
lets say I'm looking at a 250K block and a 350K house.
buying block off the plan so won;t be ready for a bit so will prob be at least 12 months between buy block and start house.
lets say i have 100K for deposit
How does that work with a loan.
Do I take out loan with full deposit for the block, then when ready for house refinance for the full amount.
or is the initial loan for the full amount and just withdraw and needed?
or take out loan with part the deposit for the house then use the rest when financed the house itself?
exactly right.
a farmer is sub diving a Padock into 6 lots
5 - 6 acres each.
but that said he needs to run power/water to each (that part of the advertisement) plus fencing and such.
it's interesting there 6 blocks 5 currently at 350K 1 at 280
so they obviously trying to work out what price they should be at, from other blocks seen for sale I think 5 are 220ish and the one I want 250-260K
Just offer what you feel it's worth in writing if he knocks it back no harm done
If it's 12 month settlement (title) you can't take out a loan as finance pre approvals are only valid for like 3 months so you pay deposit and work out the rest closer to settlement
But down the track you'd ideally borrow no more than 80% to avoid LMI
Are you going to be using a major registered builder like henley homes etc or is it a mates build type thing?
There are huge differences in how BICOE funding works depending on who's building it.
The long and the short of it, try to keep as much of your deposit free for the construction loan, not the land loan.
12 months apart they will be 2 separate deals.
So maybe use $30k max to pay deposit and legals for the block and keep as much of the remaining $70k as possible for the build.
Id try for 5% deposit on the land but if it's a developer likely they'll demand 10%
I read that as he needs to buy the land in entirity first, in which case he will need a bigger deposit for the LVR
Ham is correct.
the sub divide is passed with the council and shit but the work not done.
else would be easier.
I expect will take 12 months at least for the block to be ready to build
for ease of work this is the block looking at:
http://www.realestate.com.au/property-residential+land-vic-nagambie-201233937
and the builder something like:
http://diversebuilders.com.au/HomeDesigns/DesignDetails.aspx?dpk=20
(looking at a few builders but all similar)
and if you guys are confused think where I'm at!
That should all be doable as 1 deal so long as you pay the deposit out of your own pocket.
They are a registered builder so that deposit should be sufficient.
Ham is correct.
A rumpus, living room & family room. I wouldn't know what to do with all that space!
Makes my shoebox of a townhouse look even smaller in comparison to that haha
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
    • Do I have a series 2 or has someone spent money to have a series 1/1.5 look like a series 2? Everything I have read says the series 2 came out in 1996. I have a car manufactured in December 1995. The exterior, engine and interior are all series 2 other than the dash facia is series 1. Paint code is also kr4 that I believe is only available on a series 2. I have a VX Vehicle History Report and it says Grade: GTS25T TYPE M2 Manufacture date: 1995-12 Make: NISSAN Model: SKYLINE Body: E-ECR33 Grade: GTS25T TYPE M2 Engine: RB25DET Drive: 2WD Transmission: F5
    • I went to Repco to get them to test the battery using their tester (not a volt meter), alternator shows 14.3v when running, and when the car was off after the it was on full load I think it was 12.6v but the guy said it was all good. Terminals are all clean, no corrosion. Though I coulda sworn when I tightened up my alternator belt the car idles a bit higher and the steering wheel shakes a bit until it's warmed up. I wanted to confirm for the earth cable/s, are you referring to the 2 wires that are bolted onto the frame rail under the battery? I might be overthinking this a bit.
