It's no Hard Kandy Episode 2, but one of my favourites nonetheless
At least Hard Kandy Episode 2 was mastered properly
Honestly that decision was the pinnacle of phaggotry
nah it's more like windows 7 than 8 IMO, enterprise editions can't upgrade either - you can download the upgrade from Microsoft website if you don't have the notification, that's what I did.
#microsoftrep
I've got whatever version came with my laptop... I got the notification to 'reserve my copy' of 10 just haven't got the next one to say it's downloaded and ready to install
I skipped over ME and skipped over Vista... everything else has been getting progressively better as it goes.
I don't understand people saying that they don't like 8 and 8.1, yes its a big visual change to the Start Menu... but you how often do you actually spend in the Start Menu each day? If it's anything more than 60 seconds over the entire day, you're doing it wrong.
For me I do the logical things:
Pin commonly used programs to the task bar so they're just one click away.
Right click on the task bar -> Properties -> Always launch to desktop
If I need to launch a program that isn't pinned, I tap the windows key on my keyboard, type the first few letters of the program then hit enter... I'm in the start menu for a whole 2 seconds... Please, tell me how that's impeding on my productivity in a negitive way.
I don't get why people are acting like it's a "Tablet OS"... No, it's not... it's the same old desktop that you've used for years, they've just changed a few UI elements to make them touch friendly if you want to hang out in the start menu / those apps all the time. 100% not what you'll be doing if you want to be productive on a PC.
deeez niggros just be scared of change
  • Like 1
I might be technically inept here
But windows 8 loads up by default not my desktop but the stupid tablet GUI I don't want to know about. How do I make it start up on the desktop so I don't have to click away the tablet shit? Also do not have an easy to access shut down button - must alt F4 my way out.
And just the whole treating everything as an app thing is a dumbing down science that Apple started for idiots who don't know what a program is and can't deal with the complexity of multiple executables for that program or...application...as we called it in our day.
It definitely does compromise for tablets so they can cross platform it - case in point, desktops don't need any of that tablet UI shizzle.
Mine opens to desktop, didn't do anything to make it do that just thought it was the norm as always.
Shit like the calculator etc piss me off.. calculator used to open as a small window, so you could use it while probably calculating shit which was probably on your screen... Now it opens as a f**kin full screen 'app'. Brilliant idea.
Just had a look at it, you can 'split left' and 'split right', so you make it take up half the screen vertically... Shit like that is a pointless 'upgrade' and a step backwards. Not everything needs to be changed for something to be upgraded
  • Like 1
on a laggy connection I loath the interface with a passion.
on a local machine it's fine.
but had more bad experiences than good.
I wish ECU's were clear-cut, black & white decision :( making a choice is annoying.
Just ask what everyone else likes then do the opposite.
It's what you will end up doing anyway, why not cut out the middle man?
  • Like 1
Haha you psychic. Someone is talking me into some UK 4-cyl specialised shit. Cheaper than most standalones too.
What's so hard Leroy? You drive a Pulsar so basic is what you need: Nistune!
lol phuc u m8
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
