how was everyones week end?
Spent most of yesterday arvo chopping out rotted wooden support beams out of the bottom of a fiberglass boat. So I'm itchy as fark today.
The day started with "Lets replace the soft plywood floor" and escalated into a fully stripped hull and plans to replace seating / supports / wakeboard rope riser pole, etc
Fibreglass is good for you
Probably
Wakeboarding is amazing, will be worth the fiberglass impregnation once finished Simon...
Had my last hens party ever on sat
Dad's birthday in the evening
Slept in Sunday - doing nothing on some weekends is underrated
i never got into power water sports. its the smell of crappy fuel and people hosing off their boat after a morning of fishing. such an inefficient form of transport. jet skis ruining a perfectly quiet beach. me failing miserably at knee-boarding on an awkward ex gf's family trip to eildon. having to read speed gauges in mph.
Knots is where it's at
Also, that smell of fuel around a 2 stroke outboard or 350 inboard is possibly the best smell in the world
I reckon wakeboarding is easier than kneeboarding, was up first try on a wakey but kneeboard took a few goes
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
