Yeah the centurion card is a freaking joke. They say you need to spend $250k personal on another amex etc but I don't buy it. I reckon they will give one to anyone stupid enough to pay the rediculous fees. When I was working at Cosi soooooo many people had them.
yeh depends how you use it i guess a mate of mine not on a black but charges literally everything to his credit card for points pays it off every month so no issues there but gets free flights and lots of perks but between him and his wife i'd say they'd be well into $400k + territory
That's how a CC should be used....
they say they want $250k pa personal expenditure for centurion (no business expenses)....
that's $5k a week spending on personal shit which is why I think it's a bit of an exaggeration
if it was business expenses that's easy
OK property specialists....
Hoping to move forward with this land purchase in next few weeks.
what sort of questions should I be asking real estate agent prior to going to the bank?
WHat other stuff should I get ready prior to talking to the bank.
(other than the obvious, pay slips, car valuations, proof of deposit..)
Your first mistake is talking to a bank.
Go to a mortgage broker (mortgage choice).
They will run multiple scenarios based on your assets/liabilities and let you know the best one.
yes and no.... they will always be influenced more by their commissions than your rate
They show you all the options with their software. They may sway you to a smaller bank but the final call is yours.
I made sure they worked out the best deal with the bank(s) I wanted to do business with.
If at the end of the day you come out with the lowest interest rate at the best value (LVR) their commission is not a problem.
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
