I was thinking more Bali. Can drink couple of bintangs whilst jet skiing.
when youre in japan, drink an entire bottle of scotch and go for a drive.
10/10 will do again.
also go into random stores and tell them you know ric.
I don't believe you.
You got lost, sober, on a straight road
  • Like 1
when youre in japan, drink an entire bottle of scotch and go for a drive on a scooter.
you could have just done that in thailand for like 1/3rd of the cost.
did get lost while sober many times.
place is sooooo big.
best lost find was this ramen joint near our place. will go back next time.
Isn't there a clause - expected to work a reasonable amount of overtime?
dunno, but isn't overtime like a one off or sometimes after hours work? not every day shifts?
the explanation of this was that we have 2 10-15 minute breaks which are unpaid, so it was looked up on fairwork 'tea breaks' are meant to be paid and 'lunch breaks' are unpaid.. to which no response was had lol
Ima stay out of it tho if I want dat dere promotion
bit of a shitstorm at work re: being paid 37.5 but working 40 hours a week. This should turn out well im sure lel
My work was 9-5 (not including half an hour for lunch) = 5 x 7.5 = 37.5 hour week.
And then someone in payroll piped up that we needed to be at 38 hours to be full time or some crap... so now we work till 5:30 on Wednesday. da fk.
So its now 38h weeks, and the bosses give the biggest greasy looks at people that leave right on the dot and don't stay 30+ minutes extra each day.
In the contracts it does state "plus reasonable additional hours"
yeah we do 830-530 every day.. so don't complain about 9-530 one day! :P
get paid 38, where my backlog pay eh...
thats not including afer hours work i do or weekend work..
#IT lyf
Rest of the business do 9-5, figure that one out
Edited by UNR33L
Ours is more f**ked up than that Leigh. Two level office building - bottom level leave at 4:30 on the dot - up top we all leave at 5 (actually usually 5:30). There are more and less important roles on both levels, but the building is divided that way for some f**ked up reason.
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
