Now that we've made some of y'all some money, sell when you think you've had enough stress / have earned a tidy profit and then you can never lose.
Or...stay with me and go down with the sinking ship / into the clouds with the oil gods. Have a mate on hot copper who is currently worth 1.4 million after today's gains. Massive investment and risk but, wow. Hope to join him one day.
You're on your own!
bikes are good eh
"On Saturday i had a little motorbike accident in the Bush. Bike is in pretty good shape however after getting up and walking around, then a painful drive to the hospital, found out I have a fractured left hand, fractured right elbow, and a fractured vertebrae in my neck. Had surgery on the neck on Monday, came home yesterday, and with a bit of r&r should be back to my usual self in no time, apart from the very attractive necklace i have to wear for the next 4-6 weeks"
but for those 10 rides or less a year, im free.
would rather get injured on dirt bike i guess than death on road
or do what dezz does and go track only, ive been doing few track days lately.. mad fun
Edited by UNR33L
yeah i guess track is much friendlier conditions. and you have more choice over how hard you want to push yourself.
such a minor mistake is game over man, though.
Got my 2x speeding fines from QLD. Both on the same road, same side-of-road-camera, two different days and different directions, both 70 in a 60 zone.
Would have to have been poorly signed...
Or maybe it's that damn non-linear Speedo on the golf hire car.
negro plees, the f**kin auto is in Prius mode 24/7 which means 7th gear at +40km/h
Last hire car I had was an i30, for some unknown reason it had a Traction Control button
It's engine is enough traction control by itself
  • Like 1
did you play with the sports button on that?
The only difference I could find was that the steering sped up, no additional feel or holding gears or suspension, just a button that changes the speed of the power steering...
a button that changes the steering rack ratio is fairly impressive.
a car with 7 forward gears but only really uses 3 of them, not so much.
and a speedo that goes 0-10-20-30-40-60-80, seriously, why??? just do it after 120. only used to autobahn and private roads anyway
electric steering makes this very easy.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
