hmm never looked up those numbers before,
So a pro driver can take mine around PI in 2.01/2.02 i'm pretty happy with that.
F6 times at winton not so great however..1.43 does not seem to like corners
To be fair that's the old F6 doe :P
Gunna chuck stock suspension back on mine for mad accell
if every single one of you guys decide to pull your finger our and follow your new calling (200+ seat restaurant) and set it up through me, ill be able to buy an 2017 R35.
do it for yourself lads, do it for momo.
There's a few different variants yeah, the one they tested would of been a BF but there's an R spec etc with diff handling options on them
They did bf and fg. Couple tenths in it. Different days however.
Mid 1:43 is where it at.
Arent you nearly 30?
what have you been doing for the last 12 years?
Working in retail management, had a bad couple of years with work and places closing down and retarded owners. (never work in retail it's so depressing)
swinging his dick like a helicopter in the front hard while doing that woop woop noise that zoidberg does.
Instead of watching me from a distance stop being a fag and come join me.
e5687d3eb8bf7234c756c4fd3fcaceaa.jpg&&0){for(var>
+11ty billion on hairdressers being the most craziest. As soon as they say i'm a hairdresser i'm outta there. I wonder why they are so crazy?
Edited by scotty014
same reasons beauticians are in the same boat.
50% of their profession is talking to other women, generally the vindictive and scolding/fussy types. The same types who make sure every other women within a 50km radius knows about their triumphant divorce case to their 3 ex husbands and how to get the most out of the settlement. Theyre often career women who actually have jobs (unlike the Latrobe Valley kind that do not have jobs), so milking their 17 yro tradie boyfriend for money from unexpected pregnancy isnt the top of their priorities, but its on the list.
  • Like 2
Love is like a roller coaster; you pay a lot of money to be tossed around, and before you know it, the ride is over and you are covered in vomit. And if you are less than 4' 6" they dont even let you get on
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
    • Your off site links didn't work for me, and in any case it is easier for forum members if you post the pic directly either as an attachment or a link so the information is all in one place. That aside, the sills are the correct place to lift the car, whether with the factory jack or a hoist. Yes you should use rubber blocks with a slit for the seam on a hoist to avoid bending the pinch weld (where yours is currently bent, just bend it back if possible eg vicegrips), and be aware of the height you need in the blocks to clear any sill extensions to the hoist arms as it lifts If what you are doing needs access to the sills, the rear subframe bush would also be strong and secure. I'm not sure what you mean by sidemember (maybe same part I mean by sills) but be careful that your front support point is not too far back as the car is very front heavy and could overbalance.
    • Here's my first iteration - white duct tape so color is off, but this is just a straight line across the bonnet lip. From a geometry standpoint, this is probably closest to what a GTR has. Next up is some $5 white pearl vinyl and some rubber door sill trim, applied to the BACK of the bonnet lip. It's more accurate placement to the GTR, but also follows the body lines on this setup a bit more. Couple more pics on this config incoming: Again, a $5 vinyl and rubber job, it's  POC still and not how I'm gonna run this part. But one thing I'll note is that the black trim does need to "straighten out" a bit, and instead of going completely along the line of the bonnet lip, might be better suited to wrap over the "horns" of the bonnet lip, giving it a less aggressive curve up at the ends.  The correct way to do this would be to paint it body-matched and then decide how you want to make the black line. If you used paint or a pinstripe, you could have the black line go straight to the corner of the headlight where the rubber strip typically meets the headlight on a GTR.   Hope this helps!
