70kms I think? and then you can choose to do the second loop which makes it a 140km ride through the bush if you want. It's a full day event though, and ideally you camp nearby the night before.
Nice nice, get some motard wheels for your bike mate and come ride road shenanigans too
On the first night he spends in the White House, Donald Trump is visited by the ghost
of George Washington.
He asks him, "George, what can I do to best serve the United States?"
The ghost of George Washington responds, "Never tell a lie."
He says, "Oh, I don't think I can do that."
The next night, he is visited by the ghost of Thomas Jefferson.
He asks him, "Thomas, what can I do to best serve the United States?"
The ghost of Thomas Jefferson responds, "Do not bully the people."
On the third night, he is visited by the ghost of Abraham Lincoln.
He asks him, "Abraham, what can I do to best serve the United States?"
The ghost of Abraham Lincoln responds, "Go see a play."
long story trying to find a work shop from epping area that built a R34 GTR.
seems to be decent build
sequential box, half cage, usual suspension, custom zorst. turbos usual thing.
deceased estate so they don't have receipts only where they think he had the car had been built. circa 2010/2011
88 ENERGY LIMITEDMkt cap $206.5M
(Last 10:59 )
6.7¢3.08%
  • 6.7¢ OPEN
  • 6.8¢ HIGH
  • 6.6¢ LOW
  • $197.6K VALUE
  • 2.951M VOLUME
(20 minutes delayed)
6.7¢3.08%
  • 6.6¢ OPEN
  • 6.8¢ HIGH
  • 6.6¢ LOW
  • $164.0K VALUE
  • 2.454M VOLUME
birds pls
Spoke to an uncle of mine last weekend about it, he's a chem eng in petroleum. Was like "pfft will take years for exploration like that to be worth anything". He seems to think the Shit they have to do to make shale work is pretty ridiculous and sometimes dodgy.
down ramper
  • Like 1
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
