green wedge zone.
means i cant subdivide into blocks?
05/09/2013 VC103
35.04-3 Subdivision
A permit is required to subdivide land.
Each lot must be at least the area specified for the land in a schedule to this zone. If no area is specified, each lot must be at least 40 hectares.
A permit may be granted to create smaller lots if any of the following apply:
§ The subdivision is the re-subdivision of existing lots, the number of lots is not increased, and the number of dwellings that the land could be used for does not increase.
§ The subdivision is by a public authority or utility service provider to create a lot for a utility installation.
http://www.dtpli.vic.gov.au/planning/about-planning/improving-the-system/reformed-zones-for-victoria/reformed-rural-zones/green-wedge-zone
05/09/2013 VC103
35.04-3 Subdivision
hmmmmmm so from what i can gather, i CANNOT subdivide 8ha into smaller blocks and never work a day in my life once i sell them.
but there is the possibility of the zoning changing due to its close proximity to high st and donny brook road....
So apparently you dont get paid out super when cashing out your annual leave after leaving a job? hrmm I thought you did
"Hi Leigh,
No super is payable on lump sun termination on the leave entitlements."
http://calculators.ato.gov.au/scripts/net/SGCalculatorWeb/help/Amount.aspx?ms=Businesses
"Accrued annual leave, long service leave and sick leave paid as a lump sum on termination" is in the not-included list... So is overtime it seems...
Hamish or anyone else for that matter, have you had Kobe beef? If so, how was it?
technically no, effectively yes.
I have had beef from Kobe descendants with a pure bloodline.
Shit is flat out amazing. you can taste it the next day
by FAR the best steak I have had.
KOBE BEEF.
i start salivating whenever i describe what it tastes like.
if you want something similar, visit wagyu ya in south yarra.
also, so many people asking me why im deleting them from Facebook.
well stop posting and commenting racist anti muslim/ arab stuff you dickheads.
KOBE BEEF.
Cool going to Tokyo tomorrow night
Lots of people saying to eat Kobe beef so will have to try
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
