lol you flogs still carrying on yet I doubt a single one of you have made any significant coin in the last 30 days. Probably less than you make on your 38 hour work week.
Keep battlin labor will hand some more money out to you lot soon enough [emoji23]
found some gold coins on the ground yesterday. I didnt even have to do anything except pick them up
found some nice things on a website:
http://www.jamesedition.com/jets?order=tr
i like this one:
http://www.webforjetset.com/BOEING_757-200_VIP_YEAR_1991_FOR_SALE/BOEING_757-200_VIP_YEAR_1991_FOR_SALE-NX.htm
though, unlike a skyline, those things probably dont have forums to discuss earnings and such. shame really.
Gulfstream G650ER or GTFO
Melb -> LA on one tank.
Yes I spend way too long on Person jet websites.
I get bored in Airports and look at what it would take to not have to deal with it.
http://www.controller.com/listings/aircraft/for-sale/list/?manu=gulfstream&mdltxt=g650er
I've always wondered what the total cost of having your own jet fly somewhere long distance like that would be per flight
I'd have made trillions if dezz stayed out of 88E
never really got into the whole Pork Gyros
I know they the traditional ones in greece, but lamb tastes much better.
(oh yes I get the pork Halal thing, but considering I was drinking beer with mine not really an issue)
do you still have to go through customs (or some sort of security thing)?
it literally cant be drive through the airport in your limo to the hang, type operation
Bruh,
corelogic house price index tells me my home went up 2.4% this month. 2.4% of my $1.2mil 2 bed terrace in Sydney is $28,800!!!
You're right though, It's still less than I made in 38hrs at work.
Can't wait for labor to get voted in so they can lock out the next investors from negative gearing. Means I am in an exclusive party.
House prices to the moon!!!
domestic is drive to hanger and fly
International depending on airport they meet you at plane do customs send you on your way or you do a quick customers check in terminal and straight onto plane.
usually a separate terminal as you would not want to have to see the commoners...
Syd, Bus jets get preference over scheduled ones for take off and landing as well!
i saw something in the news about some 18yro doing a solo round the world trip. going on about how amazing it is etc etc. something like 22 stops along the way.
all i could think about was the $$$$$ on fuel and airport usage. cash'd up yo.
Martin you know way too much about this :P
3 bedroom townhouse across the road for sale, they want 600+ at auction for it! Best thing it has going for it is 3 bathrooms really, other than that nothing special. It shits me how all these new townhouses have no real lounge room just an open kitchen - gotta have dat dere chill space / tv & games spot
On another note, sold Zotac #1 from dick smiths dumpster for $200 #highroller #baller #freebie
2 more to go, this is a better investment than 88e! :D
Edited by UNR33L
airport costs are much less than you expect.
well unless you hit syd/melb
the one that local to my new place is $10 per 1000kg of plane
those round the world ones are light weight planes so not so bad.
go though asia and use off beat ones in EU and you would be pretty cheap.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
