So... how does one organize what you did in Japan, Rekin? Did want to go to Japan and do something like that quite a bit, maybe even try and JDM road trip it but never really knew how to achieve it
Setting up some HP elite x2 (basically like surfers pro 3) and they charge from USB type C port, they have ONE of them and they also come with a USB type C to HDMI adapter.. so you can't charge the laptop and present through a HDMI cable at the same time.. smart HP :D
Edited by UNR33L
http://Www.fun2drivetours.com
  • Like 1
Terrorist.
Did a supercar drive thing around Vegas canyons and was sick as well, got to drive some jag, ferarri 458, and a lambo gallardo bout 20 mins in each car but on my own and flogging them a bit. Was rad.
That moment when I have new pulley and supercharger snout, big ass new brembos and rotors, but gotta save some more cash for the intercooler and cats before I get them all on :(
Edited by UNR33L
martin, hook a brother up.
start bringing in roids or something. dezz and birds can distribute. none of this legit sharemarket shit. VWL goin places. then we can all buy yakuza cars and be conspicuous.
Dezz you still riding brah?
Track only still? I been just doing supermoto.. not getting out as much as I'd like tho as usual with bikes :(
Went to Nitro Circus the other night, that was pretty cool
  • Like 1
Why the f**k do dat dere CEOs/lawyers/etc. buy Macbooks only to have windows installed on them then create a million problems for the IT fellows when shit aint compatible
"but it looks cool bro"
Edited by UNR33L
Yer I went on Sunday, was sick as
Dem 5 person backflips from the crowd lol, I spoke to a mate that saw the Saturday one.. they did the same thing with the girl on the front etc.. made us think it was a bit staged.
Mate is in transit to America right now.. Just got a photo from my other mate he's with of him in a random search (the one in a separate room etc). Last name Saad
hahahahahah, gold
im considering a murica trip next year, any interesting shit?
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
