martin, hook a brother up.
start bringing in roids or something. dezz and birds can distribute. none of this legit sharemarket shit. VWL goin places. then we can all buy yakuza cars and be conspicuous.
When I was in Brazil all this stuff was for sale direct from Pharmacy's no scripts or anything.
they would have signs out the front with a list of what they had in stock, roids, viagra, oxy the works.
Perfect for your middle aged american there on his sex trip.
Dezz you still riding brah?
Track only still? I been just doing supermoto.. not getting out as much as I'd like tho as usual with bikes :(
I still own a bike, haven't done a track day since February I think it was.. Set a Pb after having not ridden in 6 months though so not all bad
Yer I went on Sunday, was sick as
Dem 5 person backflips from the crowd lol, I spoke to a mate that saw the Saturday one.. they did the same thing with the girl on the front etc.. made us think it was a bit staged.
I reckon it was
I can't see the liability getting away with it and the dude on the very back on the night I went, shoved himself of it before they landed - looked way too intentional
How to hack into own super account and use money for car parts?
this.
im sure one day itll come in handy...
or market will crash and lose majority of it.
I knew older people who had been putting away extra over years and had it sitting in what a super fund would consider "slightly risky" stocks. 2008-2009 market crash or whatever, $650,000 gone from some super accounts. good times.
SO most dairy farms get paid in part with stocks of the dairy they supply which for most is their retirement. (along with selling the farm)
They cannot sell until the end their contract with the dairy.
The largest Dairy company in the area I grew up is Murray Goulburn
ASX: MGC
check the 3 month/1 year of it.
as one of dad's mates put it, so that's what loosing 650K in one day feels like.
and his retirement is on hold for another 5-10 years.
I reckon it was
Don't they put the girl up the front because she is lighter though?
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
