Anyone going to the meet tonight at the docklands?
Was planning on it for a bit, but a more attractive offer may have popped up.
Will probably be at Fountain Gate meet later in the night later
Fountain gate: https://www.facebook.com/events/1243674532313961/
but leigh, you aint allowed at that one. thems the rules.
Also, just saw the traffic on the monash city-bound. f**k. that. road works has started. like 30kms of grid lock. will say no to docklands meet.
I ended up going to the docklands meet....not many skylines there!! Probably four in total. There were a million VW Golf's though.
jdm import car scene is slowly ending in my opinion. Seeing as majority are turbo and restricted from P-platers.
There is a move towards VW's/86's/euro cars which seem to be all the rage now amongst P-platers.
  • Like 1
Sad but true.
Sad but true.
the JDM boom occurred during the 2000's and all those kids from that era are now in their 20-30's.
No appealing imports have come after that era, apart from some v36's, stagea's, vip luxobarges, to catch their attention.
The last appealing car would have to be the 34GTR, but as everyone climbs the career ladder, the higher the price will go up.
The event did mention "presented by Skylines Australia - Vic" so I would have expected a slightly larger turnout! :yucky:
It was a good night though. Heaps of cars and a good crowd. Police were doing breath tests and didn't really hassle anyone. I left and there were two highway patrols sitting outside just making sure no one was silly.
The only dickhead there was a P plater ford driving around the car park revving his engine like a tool.
Funnily enough there was an event at the same car park last week which was aimed towards a younger crowd I guess, I went along with a mate and as soon as we got into the car park there was an EL ford on fire hahaha.
Side note - last night there was one of those new Merc C63's (V8 Bi-turbo). f**k me they sound so good.
So you may as well have been in peak hour traffic anywhere in Melbourne
  • Like 1
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
