yeah so covered for fire theft and such but not if it being driven.
so if you crash it driving not covered if it stolen from your garage then you are.
god for project cars and such.
and dirt cheap.
My mustang parked in brunswick then Glen iris was 150 a year. for 27K
shannons for me, there a few who do it.
Lol @ Barry's.
Scottys evo was the same. (Not that I can talk, latest engine build took 12months from drop-off to first start)
Laid-up should cover any workshop it is in, but I guess no harm in mentioning it to insurance
Had a mad day of riding today, went out to south morang go kart track, 35 bucks and a whole day of supermoto fun rotating around with the go karts for track time.
5-6 sessions later, wrecked and had to ride home an hour, sore ass now. (no homo)
Birds, get a supermoto brah, 5k and you'll be laughing again on a bike.
started a stereo install in the gloria today. it goes against everything I ever believed in cars, but apparently it should be worth the effort.
(after sitting in a well-setup car I can see what the fuss is about)
  • Like 1
geez, not screwing around there brah
do mine when you're done? :P
i only accept superchargers as payment
the entire stereo is comprised of second-hand and clearance items.
obviously sound deadening and wiring kits are new. more than I planned to spend, but i had quality splits off the pulsar doing nothing and got decent splits for the rear for $60. AND an AudioControl 8-channel, processor-factory-intergration-majiggy for $240 or so!
went to the block yesterday got some nice photos of some of the wild life on the property.
swung past today, found empty shotgun shells by front gate and a few feathers on the ground near where the ducks were and blood on the gate..
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
