Work site gets shut down until further notice... Have to hang around to do pointless tasks to appear busy. Urge to bail and watch nba at a bar rising.
Never even watched a game, but should be pretty exciting
Work cover only get involved if someone is injured. They suspect a (potentially) common defect. This is 1 week after we got the all clear from some random tests they did, it was always a crock of shit.
Most likely theyll line up a bunch of shipping containers and use that as a makeshift tunnel/blastwall so I can walk to a building in the yard. That'll take a few days. In the mean time I'm hoping Martin sends me his foxtel login details so we can stream the game.
Ahhhh the old shipping container tunnel trick...
http://www.heraldsun.com.au/news/opinion/andrew-bolt/the-case-for-voting-in-bill-shorten-as-prime-minister-and-removing-malcolm-turnbull/news-story/8260b3ac9ead7e2acd24a64f1e601192
LOL
It's amazing either how naive or genuinely stupid he is.
Reading that he clearly bases his entire political ideology on "leftists will ruin the country even when they are liberal party members" and that there is some form of correlation between how "right" someone is and their economic management abilities...
It's almost like he doesn't realise the country is run by a party, not a single person
Just heard an anti-Turnbull ad on the radio spoken by the ETU...had absolutely nothing to do with unions...or electricity for that matter.
Sex party gets my vote again; at least they stand for somethig tangible and desired
The liberal add with the fake tradie is freaking atrocious.... although no-one is going to overtake Bob Katter on bad adds this election
  • Like 1
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
